damn hedman headers
Old Jul 29, 2002 | 07:02 PM
daverr's Avatar
damn hedman headers
i have hedmen header for my car and it sucks because..
1.passenger side fit no problem...but the driverside is a different story.first off the header wouldnt line up with the cylinder head cause the header pipe hits the engine crossmember.ok after beating to fit right u find out u have another problem
2 damn pipe is the way of the sparkplug wtf.
now what is a good header for a sbc.. hooker?
dave
Old Jul 29, 2002 | 10:22 PM
johnyIROC's Avatar
What part number is that? I had NO problem dropping mine in from the top. I didn't have to lift the engine or anything. In fact I didn't even have to remove the spark plugs on the passenger side. I found that ALL of the plugs and wires are easier to change, but you must use a combo wrench to get the plugs.
Old Jul 29, 2002 | 10:30 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I can easily slip my heddman full tubes in from the bottom, I had to whack the ear off the tranny though. Yeah, as far as changing plugs are concerned, these heddmans are about the easiest I've seen. I removed the air box though.
Old Jul 30, 2002 | 08:39 AM
VampireHunterC's Avatar
I have Heddmen's on mine. After jacking up the engine, it was no problem dropping them in, they clear all the plugs, just have to get creative when I have to change them.
Old Jul 30, 2002 | 06:41 PM
daverr's Avatar
header fit
i also had no problem with putting it in, it just wouldnt line up with the driverside head.this engine i swapped in last summer its a tpi to carb.is there any differnt header out there that doesnt interfere with the cylinder 3 sparkplug.i wish i had a scanner to show u guys what kind bs these headers are.someone had to of gone thru the same stuff.my engine has worldproduct heads on it i dont if that is somwhat causing the problem.
dave
Old Jul 30, 2002 | 09:27 PM
IHI's Avatar
IHI
What do you mean interfear? That there is'nt enough clearance between your spark plug boot and the header. I wish I would have ordered angle plug heads after seeing the minimal clearance between my boots and the tubes. I have the Taylor 8.8 and their boots are big square things (I've already cinged the edges off cause they're soo close) plus it would have helped if they were all 90 degree boots instead of 1 straight boot.
Old Jul 30, 2002 | 10:30 PM
daverr's Avatar
What do you mean interfere? That there is'nt enough clearance between your spark plug boot and the header.
what i mean is u could barely put the sparkplug in.i barely could tightened it with the wrench.this total bullsh$T why would they make a header where they put the pipe in the way of number 3 sparkplug.my heads are angled sparkplug head and still in the way.
dave
Old Jul 30, 2002 | 11:10 PM
johnyIROC's Avatar
I've got World Products heads, and had NO problem whatsoever... I use a combo wrench to get the plugs all from the top. I used to have to get the back two from underneath with my manifolds.
What model WP heads are you running?
gta892000
Aug 11, 2019 11:16 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
redformula88
Oct 14, 2015 06:08 PM
cstrobel65
Sep 16, 2015 11:54 AM
