93 350 headers fit 91 305?
Old Aug 17, 2002 | 03:47 AM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
does anyone know if headers for a 93 w/350 headers with y-pipes will fit my 91 305 tpi with single cat?
Old Aug 17, 2002 | 10:45 AM
wicamaro84's Avatar
Car: 1988 camaro
Engine: 350 ci
they should since a 350 is a 305 just borded over.
Old Aug 18, 2002 | 12:17 AM
Brett Gutshall's Avatar
350 is not a bored 305, but physically the blocks are the same size. If it's the size primaries you want, they will fit. Also 93s had a single cat so I would think that would work too but I'm not totally sure.
Old Aug 18, 2002 | 02:19 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
They will certainly fit the heads. There's no doubt about that.
If you're wanting to know if they'll fit the car, I doubt it. The 93 was the first year of the 4th gen, and the LT1. So to say it'd fit, I wouldn't bet the farm on it. But then again, I never thought 4th gen interior would fit in a 3rd gen until I saw it here on this message board.
Hopefully someone who's done it, or tried it will give you a 'yes' or 'no'.
Good Luck,
AJ
Old Aug 20, 2002 | 12:40 AM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
93 LT1s are also D-ports, dunno if they would be good to use on square ports or not.
Old Aug 20, 2002 | 08:14 AM
vic_V8's Avatar
Car: RS
Transmission: 4L60
I'm not sure, but I know the ls1 headers won't, they have different heads, the exhaust ports are spread out evenly like a big block......if i remember right
Old Aug 20, 2002 | 09:54 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'm no 4th gen expert, but I would think that if those headers would fit in our chassis, it would be a well-known fact on this board.
Fitting the heads isn't the issue. Getting the tubes past the chassis is.
Old Aug 20, 2002 | 10:02 AM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I would like to know if the 93 LT1 headers would fit on our thirdgens as the heads I am using have D shaped exhaust ports. It sure would make for a better seal. Hopefully someone has tried to put these on and will tell us one way or the other.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Wvcamaro
Sep 4, 2015 08:38 PM
st.evel07
Aug 13, 2015 06:15 PM
armybyrd
Aug 10, 2015 09:23 PM
