View Poll Results: which mufflers should I use?
dynomax bullet mufflers
27.27%
flowmaster 40 series
36.36%
other " post the one you suggest"
36.36%
Voters: 11. You may not vote on this poll
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I will be running hedman long tube headers with either the s-pipe extensions or a x-pipe. I want to use either dynomax bullet mufflers or flowmaster 40 series.
which should I pick.
p.s. I will be running a 26" tall tires on the rear.
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Well I want a good flowing exhaust, but dont want the glass pack sound.
Clearance is an issue also. My car is not a daily driver, but I do take it out some. And since I will be needing two mufflers, I dont want to pay out the *** for them either.
Mark, how thick is the hooker areo chamber mufflers?
Car: 99 Formula
Axle/Gears: 342
The Dynomax Bullet is WAY to loud...my buddy has them on his camaro, and you can't even hear the blower whine over them. The 40 series is going to resonate like hell. The hooker Aero Chamber is 4.75 thick. If you channel the rear floorboards, you will have no problem. Where the exhaust bends down to run under the crossmember is the problem area.
Car: 91 RS
Engine: 350 TBI
Anybody ever use the MAC Flow path's? I've seen that they outflow the Dynomax by a little and the Flowmaster by a lot, but I've never heard one on a Camaro; just Mustangs.
