Exhaust questions
Old Nov 19, 2002 | 11:05 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
Exhaust questions
I have about 2 random exhaust questions.
1) i want to put a stright pipe hrough my cat to help make my car louder, but where can i get a cheap 3" cat? and how do i weld the pipe inside the cat???
2) i want to get hooker super comps 2055's the sorties but they are for TPI only i have a carb whats the difference in the headers to make it TPI only? can i still use them?
thanks... for the help...
Old Nov 19, 2002 | 11:11 PM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
1. no need to buy a new cat to shove a pipe through, just use the one you have now even if it is shot. All you have to do is get a 3" pipe jam it through the cat but make sure the pipe extends out both sides a little bit and weld it back onto your exhaust.
2. i believe those will work on carbs there shouldn't be any difference between the two but i am not positive. mark i'm sure will be able to help you out in that category
Old Nov 19, 2002 | 11:41 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Yes, the 2055s will work on carbs, virtually all things that fit a SBC will fit a SBC , lol.
only difference, is the stock size of the cat, the 2055s come with a 3'' y pipe.
Old Nov 20, 2002 | 12:25 AM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
1. You can take off the heast shields off the cat and then weld them onto the peice of pipe.
2. The 2055's will fit on any sbc in a thirdgen.
Old Nov 20, 2002 | 11:17 AM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
even if i have a 2 1/4 cat with the 4-bolt patterin??? i can still use the heat sheild and shove a 3" pipe through it?
Old Nov 20, 2002 | 11:19 AM
nikh23's Avatar
ah i didn't know you had a 2 1/4" cat, thought it was 3" with the talk about getting a catback. you'll have to get the appropriate piping diameter based on your cat and the rest of the catback exhaust.
Old Nov 20, 2002 | 11:37 AM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
so a blown 3"cat form a thirgen will do? those can't be what 20-30 dollars at max.. know where i can get a blown 3" cat?
Old Nov 20, 2002 | 11:47 AM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
i forgot to also ask on the hooker headers they have those little air tubes running off each primary tube what do i do with those i don't have them on my car.
Old Nov 20, 2002 | 03:24 PM
nikh23's Avatar
slice them off and use some jbweld to close them shut i believe thast what mark did if i'm not mistaken
Vintageracer
Jan 10, 2020 05:33 PM
chazman
Aug 28, 2018 03:25 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
