SLP vs. Hooker long tube
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
OK, i have SLP 1 3/4" on a solid roller cammed 406. I happened to come across a pair of Jet-Hot coated Hooker super comps REALLY cheap. So I got them because I could not pass the offer up. Question is will I see a noticeable difference by adding them?
The rest of the exhaust is a 3" random tech cat into mufflex 4".
Is it worth installing now or should I wait until the blower goes in a few years?
Steve
Steve
Your best gain would be to sell the Hooker super comps to me REALLY cheap and spend that money on other performance mods. Or sell the SLPs to me REALLY cheap and install the Hookers. Seriously, I like the Hookers better. They sound better, but I'm not sure about power gains over the SLPs. They should improve upper RPM power without hurting the low end too much. I don't know of anyone that has had both sets on their car for comparison, but the owner of the performance shop around Waco always reccomends the Hooker super comps.
82 Camaro:
350, Erson cam, ported heads, Crane Hi-6 ignition, Accel supercoil, Comp Cams 1.6:1 rocker arms, Turbo 350 tranny with 2500 stall.
82 Camaro:
Car: 1990 Formula
Engine: treefitty
Transmission: stick
I would immagine that going for the cheaper headers is your best bet,IMO.Unless money is no issue.
They are the same as far as pipe diameter, right? If so, performance gains/loses shoud be neglegable.
1990 Formula
Factory:TPI-305/Dual Cat(230hp),5 Speed,3.42 rear, Dealer:Aluminum Drive Shaft
Mods:SLP air foil,K&N Filter, Accel:wires,coil cap,rotor.Hypertech Thermomaster chip,Stat,Fan switch,TES headers,MSD6AL,Flowmaster 3" Cat-back exhaust,TB coolant bypass, Centerforce clutch (going).
1990 Formula
Car: 90 Camaro RS
Engine: 305 TBI
ponti- the main difference is the hookers are not shoved into a tiny y pipe after less than half a foot of primaries, the hookers wind around for about 2 feet then go to a 3 inch y pipe unlike the slps. i think you should install those bad boys and let us know once and for all which is better....and why....im sure you will find the LTs are the winner.
Dont forget you need a y pipe for those bad boys....unless you already have one
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 3/4 LTs, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit (corvette servo here...but not installed yet)
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
http://www.geocities.com/esvalenz
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
"Just because I've done it, doesn't mean I knew what I was doing!" - Me
Rick
