Notes on Installation of Hooker Long Tube Headers (2210)
Old Aug 6, 2003 | 04:26 PM
  #151
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
also im kinda trying to keep it not too loud becuz its still my daily driver until i get a truck, so i think i might stay with the hooker just for now becuz its still quite but when i get on it its loud. just dont want to cops pullin me over and findin no cats on the car ouch $5000 fine
Old Aug 6, 2003 | 08:39 PM
  #152
IrocindatZ's Avatar
Car: 1989 IROC-Z
Engine: 350 TPI w. Bolt_ons
Axle/Gears: Dana 44 3.73
Ok ya to the guy who posted the sound clips try reving the engine instead of just letting it sit there..
Old Aug 7, 2003 | 06:17 PM
  #153
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Ok ya to the guy who posted this ... try contributing something instead of criticizing.
Tim
Old Aug 7, 2003 | 06:20 PM
  #154
IrocindatZ's Avatar
Car: 1989 IROC-Z
Sorry i didnt mean to be rude but how am i supose to know waht it sounds like if its just at an idel????
Old Aug 7, 2003 | 06:29 PM
  #155
TRAXION's Avatar
The 'sound' has almost nothing to do with this post. It's really about the installation of LTs. The sound is more dependent on your cam, your catback, and whether you have cats or not. The LTs just emphasize the exhaust pulses. So, if you are looking for a 'cool' WOT sound then you may want to look at other posts. Find a muffler that meets what you are looking for and then run it with no cats.
Tim
Old Aug 28, 2003 | 03:26 PM
  #156
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
I just finished up my install of the headers myself...
for those who want to know, i converted a 91 TBI friebird, keeping the a/c to a 350 carburated monster...
I did indeed use the mufflex y-pipe. It came to me in a half a dozen or so pieces, and i was able to fit it and weld it to give the maximum ground clearence and chassis and frame clearence bewteen its self and the frame.
I will be the first to say with the hooker cat back (3", i dont have the cash for the muflex 4" cat back rtight now) that it sounds unbelievable.
As for ground clearence, i have stock suspension (springs ans struts soon to be replaced) and the lowest part int he system is the y-pipe. I'm not sure how you guys get away with lowering your cars with this system! my y-pipe is tucked up as high as it goes, and i have measured a max of about 3 1/2" of ground clearence at the lowest poitn in the system, which is NOT the headers, but rather a secton of y=-pipe.
Anyone with any questions, or someone who needs some pics, lemme know, i can help out immensly. I also did this install with the poly motor mounts...
Old Aug 30, 2003 | 08:02 PM
  #157
OMINOUS_87's Avatar
Well I guess I am the latest to join the club.
So far everything has gone real smooth, only 50% done but there is still pleanty of time left in the weekend. I have finished the driver side in its entirety. The LT slipped right in from underneath without having to jack up the motor, I did remove the oil filter and pressure sending unit though, they did cause clearance probs for the initial slide in. After bolting everything up I have nothing touching anywhere, I have all kinds of clearance all around the LT. I am running straight plugs that are a bit tight but not touching, E-tec heads.
I will finish the passenger side later or tomorrow and report back, I am crossing fingers and hoping that it will go as silky smooth as the driver side.
By the way for anyone interested, I picked up my set of 2210 LTs with ceramic coating and Mufflex 3.5" back with custom 3" y-pipe gently used for 400$ cash. Its real nice when the performance *** smiles down on you or when rich folk decide to go twin turbo and sell their parts to the first poor fool with a few bucks in his pocket, aka me.
Old Aug 31, 2003 | 01:04 PM
  #158
OMINOUS_87's Avatar
Well, the passenger side turned out to be a PITA. The LT was actually touching the k-member in 2 places and also touching the brake hard line. The brake line was easy, just a little bending and pushing on it took care of the issue. The k-member touched in exactly the same spot as it did for Traxion, on the a-arm mount, as well as right along the weld of the k-member. I easily cut the weld down and slightly dimpled the LT where the weld was touching, solved. I just put a new disk on the cutoff wheel and plan to go to town clearancing the a-arm mount.
But all and all everything else was ok. I removed the knock sensor and fan switch and the LT slid in pretty easy without the use of a jack. So far its been in and out 3 times to check for clearances, piece of cake.
Well, back to work, gonna get this thig done today.
Old Sep 7, 2003 | 09:21 PM
  #159
CamaroEFI's Avatar
i have a 91 RS 5.0, 700r4. all the suspension is factory except i have shorter tires on the front. im getting headers real soon and i was thinking about the hedman shorties but what i really want is longtubes. i just want to know if i will be able to fit them in there and what i will have to do to get them in the. i've been reading everybody elses post but it seems nobody has the exact setup as me( different head, different engine mounts, different trans, etc) i don't even know if any of that stuff matters but i just want to be sure before i order them.
Old Sep 7, 2003 | 09:33 PM
  #160
OMINOUS_87's Avatar
What do you have that might be different then what is listed above? There are all kinds of players in this thread with all kinds of differnet combos.
Old Oct 28, 2003 | 12:08 PM
  #161
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Coated Hooker 2210s
No pics yet, but mine are in. Here is a rundown on how it went for me (forgive me for some of the redundancy per previous posts/results).
Everything went pretty well. I had to clearance the LCA mounting area of the K member on the driver side per Traxion's instructions, but not on the passenger side. My slip tube primary has lots of clearance. The passenger side did need a little grinding done where the factory welds the upper and lower halves of the K member together. The #4 (I think - I'll edit this as necessary when I get out to look at it again) primary gets close to it as it runs down to the collector. The factory weld was pretty sloppy and it stuck out and was hitting the primary tube. I ground it down until I had a good 1/8" clearance which meant it got pretty thin. I didn't grind all the way through the K member steel but pretty dang close . I doubt a little thin spot like that will affect its rigidity though.
I relocated the knock sensor to the driver side per Traxion's instructions.
I had to move the passenger hard brake line. I removed the bracket in that area to gain more freedom of movement for the line and bent it down and forward and have a solid 3" of clearance all around from the headers.
I already had a ministarter and it fits perfect.
Dipstick tube was not an issue. I put the stock one back in but haven't figured out a mounting setup for the upper part of it yet. Luckily my Canton pan pretty much clamps down on the tube when I tighten the bolts so it certainly won't be going anywhere anytime soon .
I have standard SBC angle plug heads (see sig) and the plug clearance is great - not a single issue at all.
I have the OEM tired rubber engine mounts .
They fit great with the T56 too. No clearance problems at all. I had O2 bungs welded onto both headers. I did the driver side one like Traxion did and close to the same type of setup on the passenger side. I had that one canted slightly at an angle towards the passenger side of the car to get even more clearance from the bellhousing of the T56 but it could be installed straight up without a problem. Ran me $20 at a local race shop plus the cost of the bungs. For now I just stuck my old 1-wire O2 in the passenger side and put a 13077 HO2 on the driver side for actually running the system. The long term plan is for a WBO2 for that side as well as moving sensors from bank to bank to verify the state of tune of both sides. Who knows... maybe even a system like an LT1 PCM that uses dual O2s will be in the picture later on.
The y-pipe has not been started yet. I plan on getting started on building a custom crossmember later this week that will make as much room as possible for the Y-pipe and then taking it to a local guy that has been well recommended for the Y-pipe construction.
I will try to get some pics before the week is over and for sure after the Y-pipe is done.
Hope that helps people some .
Oh yeah, and many many thanks to Traxion and the others that have made this a MUCH easier install than it would otherwise have been .
Old Oct 30, 2003 | 05:34 PM
  #162
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
I installed my LT's not too long ago. I pretty much did not modify ANYTHING, honestly. The only catch for my car was that I had to install them pretty much vertically from underneath the car, which was a major pain in the *** because I didnt' have enough jacks to get the car that high in the air. I already had a mini starter too, and I have angle plug Canfield alum. heads. Car sounds MUCh better. I also had a dual 3inch X pipe exhaust made at the same time, with under the axle mandrel bent piping and 3inch magnaflow mufflers at the rear of the car, ala late model corvette style Sounds ****ing sweet. Not that loud, just REALLY deep and rumbly.
Old Oct 30, 2003 | 05:36 PM
  #163
Car: Junk
Oh yeah, did I mention my car is lowered 2 inches?? Ground clearance is fine as long as I go over speed bumps sideways and don't fly through intersections with huge dips in them.
Old Nov 1, 2003 | 01:20 PM
  #164
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
ChrisFormula355, do you have any pics or could you get some. I just bought some 2210s and want to do an x-pipe setup but can't find any real good pics besides 4th gens.
David 91RS/Z28 do you have any pics of the passenger side sub frame connector. Im worried there wont be enough clearance for an x-pipe setup.
Does anybody have any exprience with
this starter?
Old Nov 1, 2003 | 01:59 PM
  #165
Momar's Avatar
I have an h pipe, but plan on switching to an x eventually. You will need to get s extensions to clear the subframe before it goes into the x though. I tried running a pipe straight back and it just hit the subframe on the passenger side.
Ben
Old Nov 2, 2003 | 10:44 PM
  #166
Car: Junk
this starter?
I have some awesome in-the-air pics of it from when it was on the lift at the exhaust shop........only problem is that they are on my buddies digital camera. Will post them in the next couple days when I get over to his house.
Old Nov 2, 2003 | 10:46 PM
  #167
Car: Junk
this starter?
that starter looks damn near the same as the mini-starter I'm running. I got mine from the local speed shop, was an off-brand so I couldn't tell you the exact brand, but it was about $130. Works sooooooo much better than a stock starter. My stock t-5 starter couldn't even crank over my new 355 in my firebird. I had to upgrade just to start the new motor!
Old Nov 4, 2003 | 12:34 PM
  #168
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
this starter?
I have the x-pipe setup you're talking about. It's the same one 11Sec91Z has, I think he has some pics. Check out 87_TA, I think his setup is similar. My mufflers dump right under the rear axel. I'm going to eventually move the mufflers back and run mandrel pipes up over the axel on both sides which will be a tight fit. I think a car looks much nicer a "full" exhaust.
If you're thinking about the summit mini-starter, it works great. The price is right too.
Old Nov 13, 2003 | 08:08 PM
  #169
rjmcgee's Avatar
Ok, I read this whole damn thing before asking, will these fit with a mechanical clutch linkage? Has anybody tried it? Thanks
Old Nov 13, 2003 | 08:54 PM
  #170
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
ChrisFormula355, ever get pictures?
Old Nov 17, 2003 | 02:51 PM
  #171
Car: Junk
Yes, look in the post a couple below this one.
Old Nov 17, 2003 | 02:53 PM
  #172
Car: Junk
or just check em out here:
Old Dec 16, 2003 | 04:45 PM
  #173
Dean-B4C6SPD's Avatar
Passenger side hits LCA
As Traxion and others mentioned before, my Hooker LT hits in the exact spot as photographed by Traxion. (passenger side)
Well, my question is.. how much clearancing is TOO much clearancing - that you start to affect structural rigidity ???
I clearanced the exact spot that was photographed..but by clearancing, I first cut 1 inch rectangle, then 2 inches, now it is almost 4 inches of a rectangle that I have clearanced out of the LCA area (like the photo shows) It seriously won't fit otherwise... motor mounts have like only 8k miles on them... (It is just the standalone #8 cylinder pipe thing that hits)
I'm wonderng how that will affect strength and such??
Dean
92 B4C, LT1 and 6spd
Old Dec 16, 2003 | 05:13 PM
  #174
OMINOUS_87's Avatar
Before you get to carried away on grinding the K-member down to nothing for clearance, dont forget how effective a hammer is.
I did quite a bit of grinding and then called it quits and lightly dimpled the #8.
Just mark the spot that doesnt clear with a felt pen and then slightly dimple it with a hammer, it is helpfull to put a thin rag on the #8 as to not ruin the ceramic coating.
Dont foget to get some Ultra Copper RTV around that #8 before you slip it in permanently.
Old Dec 27, 2003 | 03:10 PM
  #175
Matt87GTA's Avatar
OK, got a digital camera for Christmas (yeah! ) so I shot a few of my Y-pipe and how low my collectors ended being (very , but then again, so is the SFC X-member as you can see). You can see a little bit of my custom fabbed T56 crossmember too. Check em out:
It's 3" and it has the rear collector flanges for facilitating pulling the trans and not having to take the entire exhaust system off the car to do so.
Old Dec 27, 2003 | 03:42 PM
  #176
fb305svs's Avatar
I have to say, mine hangs pretty low, but since the addition of new shocks, i never hit on anything anymore... altho, granted, my car is not lowered...
Old Dec 27, 2003 | 04:42 PM
  #177
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Nice pictures! And that is with the pro kit? Looks low, but good. Any side shots of the car?
Old Dec 27, 2003 | 06:32 PM
  #178
Matt87GTA's Avatar
Yeah, that's the Pro Kit... I took a little off the front springs though so it is maybe 1/8" lower in the front than a stock Pro Kit.
I can't get a decent side shot of the car right now because it is in the garage but there are a quite a few different pics on my site of the car (see link in sig).
Old Dec 27, 2003 | 06:55 PM
  #179
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
what are you running for motor mounts?
Old Dec 28, 2003 | 06:33 PM
  #180
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
cool, thanks.
Old Dec 28, 2003 | 08:26 PM
  #181
fb305svs's Avatar
Energy suspension poly's here... only clearence issue i had was the a frame... lopped off a small piece of it, plenty of clearence.
Old Jan 14, 2004 | 01:35 PM
  #182
ChevyCamaro4lif's Avatar
REALLY NEED AN ANSWER TO THIS.....
WOULD THERE BE ANY CLEARANCE PROBLEMS IF IM USING THE HOOKER SUPER COMP LONG TUBES ON MY 91 Z 350 W/TRICKFLOW HEADS AND....I HAVE PA TUBULAR A-ARMS AND TUBULAR K-MEMBER???
Old Jan 14, 2004 | 04:13 PM
  #183
fb305svs's Avatar
well i have trickflow heads, and i ran into minimal clearence issues on the stock frame. i would guess you would have more room than anyone inthe world if you have all the tubular stuff, the mount points of all of it shouldnt be any different than stock...
Old Jan 14, 2004 | 08:46 PM
  #184
ok thats good to hear.
now another question about these headers 2210...
when all bolted up to the manifold, are the collectors at any angle downwards toward the pavement/ground? i would like to set up a true dual system and im buying mostly stright pipes and i was wondering if i was gonna need to bend any tubing upwards close to the frame to stay away from the ground or if i can just bolt them up to the collectors and they'll be set nicely under the car??
Old Jan 14, 2004 | 09:20 PM
  #185
fb305svs's Avatar
the collectors sit fairly level with the ground/chassis... you will likely need to do some, but not much creative bending to clear the trans crossmember... i'f your gonna stray to do your own customsetup, then your pretty much just gonna have to go play by play with it, ya know what i mean?
Steve
Old Jan 14, 2004 | 09:37 PM
  #186
Momar's Avatar
You shouldnt need to bend anything if you get the hedman s extensions w/ the 2210's, and then run pipe back. The xtensions put the exhaust right in the edge of the tranny tunnel and give the clearance of the frame needed.
Ben
Old Jan 14, 2004 | 10:11 PM
  #187
does anyone have a part # on these extensions or a website where i can check them out?
also i forgot to mention my plan is to exit before the rea wheels at the sides with 4" slash cut 18" long tips.(if that affects anything)im prob gonna go headers, h pipe, bullets, then out to the sides with 4" tips. thats what i would like to do or eveything but the h pipe.
Old Jan 14, 2004 | 10:16 PM
  #188
Momar's Avatar
Well, what I would suggest is to climb under the car and study where you want to route it. There are a couple possibilities. You could do like I mentioned and buy some 45 degree bends to aim it toward the side after the subframe, or you could turn right off of the collector and go outside of the subframe that way. The tough part if you turn right away would be doing an h pipe.
Like I said, I would get under the car and see what you think you would be able to do best or would rather do and then maybe we can help some more from there.
Ben
Old Jan 14, 2004 | 10:40 PM
  #189
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
anybody got any pics of a spohn torque arm, or know if the hedman x-tensions would clear?
http://store.summitracing.com/partde...57#largerimage
Old Feb 28, 2004 | 08:11 PM
  #190
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Heres a shot of how horrible my #7 spark plug interference is with Vortec heads. I'm running a shorty plug and have a huge dent in the header tube and the boot still touches it. I put like 5 layers of heat shield tape on it ...boot hasn't burned yet but I still check it every time I pop open the hood.
Attached Thumbnails Notes on Installation of Hooker Long Tube Headers (2210)-vortecclearance.jpg
Old Feb 29, 2004 | 11:01 PM
  #191
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
wow thats tight spot there, i got stock straight angled plugs and i made my own shorty plug out of an ACdelco plugs and i have great clearence around my number 7 tube.
Attached Thumbnails Notes on Installation of Hooker Long Tube Headers (2210)-clay8.jpg
Old Mar 31, 2004 | 12:11 PM
  #192
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
where, i cant see it just put on my driver side, with the oil filter, pressure su, and slave cylinder outta the way, motor jacked up, it slipped in easier then my hedman shorty did. with my stock heads, accel header plug, accel wires, ive got about 1/4 of clearance. ill take a pic later
Old Apr 7, 2004 | 11:10 PM
  #193
racindaelky78's Avatar
Car: 1978 El Camino
Engine: 3??
Transmission: th350junk
im doing the hooker long tubes on a friends car,i had to raise the motor 3 inches,i also ran into a problem but not with the kbar but with the lower control arm rear mount needing to be shaved down about 1/4-1/2 inch,and i cannot get this passenger side in with the car being raised almost a foot in the air. How did you exactly do the passenger side header, to get it in without jacking the motor? and again this side needs that mount shaved as well.
Old Apr 7, 2004 | 11:31 PM
  #194
Car: '89 IROC-Z
Take the starter out and point the header so the collector is facing straight down at the ground...Then slowly push it up right in front of the bellhousing ...you then should be able to to rotate it clockwise into place.
Old Apr 7, 2004 | 11:58 PM
  #195
Car: 1978 El Camino
Engine: 3??
just go straight up then, ive tried every angle,starters out of it, and it wont sit no clearance and this car is up there, ive almost got it to go in from the top, im just 2 inches from ebing clear oon the top, saturday im giving it another shot after i grind off those two mount tabs.
thanx for the pointer though im going to try and get the car higher.
Old Apr 8, 2004 | 06:57 AM
  #196
TRAXION's Avatar
5) I had to grind on the passenger side of the k-member where the LT was touching. Primary tube #8 was touching the K-Member here. This had to be clearanced for my application. Click HERE to see the problem.
6) The driver's side header demands that you jack the engine up in order to slip the header in from the bottom. You’ll have to remove the oil sending unit and the filter.
7) The passenger side header slips in with no jacking of the motor (starter removed).
8) To install the headers you want to point the collectors STRAIGHT down at the ground and rotate into place.
The key is to point the collector straight down. If you can't get the collector to point straight down then jack the car up more. I originally said the same thing that you are saying. Then I tried with the collector straight down and it rotated up into place. You can't get the header in from the top - give up on that idea.
Tim
Old Apr 8, 2004 | 11:26 AM
  #197
Car: 1978 El Camino
Engine: 3??
Tim
ok cool, im used to doing headers on my own car and that takes me 10 minutes a side,not 2 days for one side.
Old Apr 8, 2004 | 11:28 AM
  #198
Car: 1978 El Camino
Engine: 3??
K-MEMBER? what is that? im having clearance problems on the suspension mounts,im ready to have this kid order tubular upper and lower control arms so i can get this excess metal out of the way for good.
Old Apr 8, 2004 | 06:38 PM
  #199
fb305svs's Avatar
are you workin on an fbody? no upper a's bud...
the k member is the engine cradle, spring pockets, and the mount point for the lower a frames...
Old Apr 10, 2004 | 03:41 PM
  #200
Car: 1978 El Camino
Engine: 3??
im used to my g body that this thing is unbelievably the biggest pain in the ****! what holds the lower control arm in isnt the problem on the passenger side, its the tranny bellhousing flange thats in the way and im not gonna cut that apart or have him do it.
