Thermo-Tec Header wrap ( for headers of course)
Old Mar 6, 2001 | 06:51 AM
vortech305's Avatar
I know its probably not necessary, But im really interested on buying header wraps for my 92' camaro(88' 305 TPI motor). U can see my modifications on the sig down below, But before i get the header wraps just curious to find out their goods and bads. I have edelbrock's TES headers and i believe they are the 16 gauge steel. Now i sprayed high temp. header coating paint on it and im sure its just gonna peel off. I heard the header wraps trap so much heat on your header they tend to bend and deform the headers. So thats why im asking you guys for help. I know getting them Jet hot coated is probably better but i really dont want to go on my way on traveling places or sending my headers to a shop. If possible please note the goods and bads on the header wraps and if u believe i should install it on my edelbrock headers. Its only $70.00 to fully fit all both sides so please help me out.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
Old Mar 6, 2001 | 07:33 AM
Kenn's Avatar
Man let me tell ya
I just took off my Edelbrock TES that I installed Nov 97 with header wrap -upgrading to Hookers 1 3/4- and I didn't witness any of the disadvantages associated with excess heat being trapped between the wrap and headers- they didn't melt, sag, rust or catch fire - the advantage I can vouch for is the cooler underhood temps
You were smart to paint the headers first (I hope you stripped the factory paint off first ) I didnt and under the wrap the factory paint burned off - but no serious amount of rust accumulated - there was a lot more rust on the flange and air tubes - I didn't want to waste the film but I'll take pics and post em
I really don't understand why so many people hate it
Old Mar 6, 2001 | 08:25 AM
vortech305's Avatar
Dont give me too much credit, cause i think i screwed up. I sprayed one coat of 2,500 header coating every hour for just two hours (two coats) and i believe u need to put them in your oven and leave it at 350 degrees or something and i didnt do that. All i did was spraypaint it and let it dry. Before i put the header wraps on should i take away the high heat coat paint. I dont see it in the back of the can to put it in an oven or something. Sorry im just new to this header thing. I did scrub away that black residue that comes with the TES headers. Can u just give me a procedure, once again im sorry.
92' camaro
Soon to come!!!
Other car;
Old Mar 6, 2001 | 09:30 AM
Kenn's Avatar
you're ok with taking off the factory coating and using hi temp paint on the bare metal to protect it- them wrap em- oven heating is a toss up IMO since the paint can cure with exhaust heat
for the headers I got now I chemically stripped all the factory paint off- paint, bake 400deg- paint again no bake- wrap - then painted the wrap-
Old Mar 6, 2001 | 11:55 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Dont wrap them. Every header manufacturer will void your warrenty if you do. Header wrap is evil. Yes it traps the heat inside, it traps so much heat that it actually melts the headers and causes them to crumble.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 6, 2001 | 12:34 PM
vortech305's Avatar
hey kevin have u had a problem with a header and the wrap and by the way since i just added only two coats of high temp. spray paint on the header and just let them dry, is it still effective or will it peel off the moment the motor runs. I dont know im still skeptical, i wanna get the wraps but i need a few more suggestion from others, ill keep your info in mind thanks everyone.
92' camaro
Soon to come!!!
Other car;
Old Mar 6, 2001 | 07:46 PM
The ODB's Avatar
forget the paint, get the wrap.
the wrap works super. I have used it on mild steel TES and it did reduce the life of the metal some, but 7 years was still plenty of life for some cheap headers to last with daily usage.
I like the thermotech wrap.
Old Mar 7, 2001 | 10:36 AM
vortech305's Avatar
great im gonna order it today, and since im sorta new to this header wrap, one more question. Do u have to coat the wrap with something or just put it on and hold it with steel clamps?
92' camaro
Soon to come!!!
Other car;
Old Mar 7, 2001 | 01:38 PM
FiReBReTHa's Avatar
DeaR GOd, How frekin big is you guys's ovens???????????
91 FireBird 305 V-8
no true mods,
ghetto rigged cold air intake,
People dont have a soul, its just something parents made up to frighten little children, like the boogie man, or micheal jackson..."
GheTTo Riggers INC.
We Make Mcgyver look Like Crap
Old Mar 7, 2001 | 02:13 PM
Kevin91Z's Avatar
I painted mine with some 1500º aluminum spray-coating. Yes, I've seen headers crumble after they've been wrapped. Try calling Dynomax, Hedman, Hooker, Edelbrock, and SLP, and ask them if they recommend header wrap. My bet is they'll say no, for the reasons I've given.
Old Mar 7, 2001 | 06:05 PM
vortech305's Avatar
Great now ive got some people saying they have seen headers crumble with the wrap and others say they love it. But since ODB has used it for 7 years, ah what the hell, u live once right im ordering them right now. Hey ODB u wouldnt happen to have a pic of your wrapped header a while back. I hope edelbrocks 16 gauge steel will hold up..
92' camaro
Soon to come!!!
Other car;
Old Mar 8, 2001 | 09:02 PM
The ODB's Avatar
I use hoseclamps on mine.
yeah the TES lasted 7 years and are still wrapped. The Y-pipe was also wrapped and is basically unusable by the 7 year mark. The Y-pipe has rusted and is crumbling, but the headers are fine still. TES will not last forever no matter what you do, so I say the benefit is well worth the damage to the headers.. they are cheap anyway.
my SLP's are wrapped the same way, and I'd wrap any other header I run in the future no matter what the maker says. It's not like I'm going to ask the company to replace my headers after I race with them for years.
I have no pics of the TES but I have a couple of the SLP's I think. Email me and I'll send them to you.
oh yeah
*do not microwave your headers
Old Mar 9, 2001 | 08:46 PM
84TransAm's Avatar
Someone told me if i don't use header wrap, or tape on the Y pipe, then it will melt my Slave cylinder! I hope not!!
--Steve S--
1984 Trans Am 305 LG4, 5 speed
Daily Driver, Flowmaster 80 Series
NOW FEATURING: Holley 600 cfm & vacuum advance
Old Mar 9, 2001 | 08:59 PM
The ODB's Avatar
i don't know about that one, but you can sure burn your hands while messing with plugs or wires.
also rumors that wrapping your pipe too much can make you go blind*
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
Accerrito22
Sep 5, 2015 09:34 PM
