need help fast
Old Dec 20, 2002 | 10:48 AM
19WS6T/A91's Avatar
need help fast
im installing headers as you read, i seem to have lost the connector for whatever sensor plugs into the drivers side head(is it the temperature switch?) anyways, whatever it is i need to hook it up. i was just wondering if anyone can tell me where that wire ends up going so that maybe i can track it backwards.
thank you,
david
Old Dec 20, 2002 | 10:52 AM
Shagwell's Avatar
Car: projects.......
GM was horrible abou those temp switches. My car has one in each head...figure that one out. - anyhow, the wire should be green(not sure there), and root w/ your O2 wiring(definit)...
Old Dec 20, 2002 | 11:48 AM
19WS6T/A91's Avatar
thanks for the info, my dad figured it out right before i came and checked this.
thanks,
David
Old Dec 20, 2002 | 11:55 AM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
I take it your fuel injected then??? one in the pass head is for the fans, one on the drivers side head is for the guage, If TPI the one under the TB is for the ECM. Hope this helps with your curiousity?
On my part...91 TA..yeap TPI.
Old Dec 20, 2002 | 03:49 PM
Shagwell's Avatar
Cruzin Kaz - that explains it. But how come if I unhook the computer one, the gauge doesn't work? - aaa, who cares, my 750 Holley and mechanical temp gauge don't...
Old Dec 20, 2002 | 03:55 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Good question...Maybe some years were different then others??? Anyone else???
InfernalVortex
Apr 20, 2021 11:31 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
sreZ28
Oct 22, 2015 08:21 AM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
