My header bolts loosened up, I could turn them with my fingers!!!
Old Dec 25, 2002 | 07:16 AM
bad84z's Avatar
Car: 84 Z28
Engine: 355
Transmission: 700R4 with corvette servo
My car started making this tapping noise, and it just kept on getting louder and louder. I took off the valve cover from the side the noise was coming from and tried to see if it was coming from there. I put my finger on each one and the noise didn't stop. D@m, that wasn't it. So I got to looing around, and discovered that my header bolts were really loose. I tightned them up and I would say it could out about 75% of the tapping. Only a little tap there now. Would this have blown my gaskets out, do I need to replace them.
Old Dec 25, 2002 | 11:25 AM
87 B4Z's Avatar
headers bolts backing out is nothing new. every once in a while i have to retorque mine.
Old Dec 25, 2002 | 12:20 PM
bad84z's Avatar
Car: 84 Z28
Engine: 355
Anyone ever use any lock tite, or a lock washer or somethin to keep them from comin loose??? Two of the bolts are really hard to get to, I wander if there is any trick to getting them to stay tight.
Old Dec 25, 2002 | 03:15 PM
Rob116's Avatar
Car: 1986 Z-28 Camaro
Engine: 355
I've got hedman lock washers on mine... people say that the stage 2 locking header bolts work really well, but they do come at a bit of a price. Loctite won't do a thing - the temps just get too high for it, even the "high temp." stuff.
87 B4Z's Avatar
i would'nt use any lock tight, what kind of headers do you have, what kind of bolts are you using? i have had headers on my car for a little over a year and only retorqued then 2 times. the first time was a few day after installing them and the i did it again back in ther summer. both times they were'nt even very loose.
Old Dec 25, 2002 | 03:37 PM
bad84z's Avatar
Car: 84 Z28
Engine: 355
I have edelbrock headers on my car and the bolts just look like normal bolts, nothin special.
Old Dec 26, 2002 | 03:43 AM
MdFormula350's Avatar
maybe try some locking washers like said, that might help.
or make sure each bolt has the same torquing.
Old Dec 26, 2002 | 08:41 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
When you installed them , after you heated the engine up once, did you retighten?
also, check them every so often, which is a good idea, unless you want to invest about $40 into locking bolts.
I know when one of my bolts fell out, it burned the heck out of my fel pro gasket.
Old Dec 26, 2002 | 09:16 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Stage8 header bolts. I've had mine on for over 3 years and would recoomend them to anybody with headers. Very wise investment.
Old Dec 27, 2002 | 06:57 PM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
If you don't want to retorque semiannually, go with the Stage 8 Header bolts, and Percy's gaskets. Yes, quality comes at a price, just check Ford's "Quality is Job 1" F150's... LOL
Old Dec 28, 2002 | 08:10 AM
87 B4Z's Avatar
im using ARP bolts and im not having any real problem with them backing out.
Old Dec 28, 2002 | 10:12 AM
bad84z's Avatar
Car: 84 Z28
Engine: 355
replaced my header gasket and bolts today. The bolts I put back are longer than the ones I took out. So, I am hoping they will hold better. The old ones I had in had lock washers on them, but they obviously did not help. Here is a pic, check out how much long these bolts are. The bolts are spectre. It did not say what stage or grade they were, but I have never had any problem with there producs before. Besides, I really torqed them down and none broke off.
Attached Thumbnails My header bolts loosened up, I could turn them with my fingers!!!-pics-083.jpg
Old Dec 28, 2002 | 10:13 AM
bad84z's Avatar
Car: 84 Z28
Engine: 355
heres another pic
Attached Thumbnails My header bolts loosened up, I could turn them with my fingers!!!-pics-084.jpg
Old Dec 28, 2002 | 01:30 PM
hope they fix the problem you had..
Old Dec 28, 2002 | 11:57 PM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Bad84Z said "It did not say what stage or grade they were"
Bad,, Stage 8 is the company name, not a particular grade. They use clips to keep the bolts from backing out..
Tony
Old Dec 29, 2002 | 01:00 AM
bad84z's Avatar
Car: 84 Z28
Engine: 355
Tony
D@m! Thanks man, that had me confused. I had never heard of those before. I hope these work fine.
Old Dec 29, 2002 | 01:43 PM
breathment's Avatar
definatle go with Percy's gaskets. not only are they reusable and blow proof. but they look awsome compared to crappy paper gaskets.. only problem i had with them, is they moved my headers out about 1\16 of an inch, so it now comes into contact with my steering shaft
Old Dec 29, 2002 | 02:21 PM
bad84z's Avatar
Car: 84 Z28
Engine: 355
Actually, I bought the mr gasket. BUt not the cheap paper ones. These were 16 bucks for the pair. They are pretty thick.
Old Dec 30, 2002 | 11:28 AM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
Stage 8 's are great. Don't back out....
evilstuie
Jan 9, 2020 08:29 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
red90IROCls1
Aug 25, 2015 06:56 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
