High Output question
i have an '85 camaro iroc z (305 T.P.I., 700-R4 trans, automatic) and i was looking to buy a hooker cat-back exhaust system for it. this might be a dumb question, but i dont know if my car is High Output or not. please let me know if there is a way whether i can find out or not. thanks.
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
You have an LB9, the L69 was called the 305 H.O. engine. I'm not sure, but I think some do refer to the 305 TPI as H.O. also.
Car: 99 Formula
Axle/Gears: 342
I'm pretty sure it's only for the HO 305 carb cars. Look at your cat, does the back end have a 4 bolt rectangular flange? if so, it will bolt right up, if not, you will need some fab work done.
Dialed_In
Aug 20, 2015 01:45 PM
