when is it time to go from 3" to 4"
Old Jan 2, 2003 | 09:19 PM
Kandied91z's Avatar
just curious, i have 3" right now; but i'm replacing my engine with something better hopefully soon here. i'd like to be good for up to 600 range.
Old Jan 2, 2003 | 09:25 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
If you had done a search, LOL j/k
irocztwentygr8 posted this a few days ago, off of a website.
HP-------Single----Dual
200-300----3"------2.25"
300-400---3.5"-----2.5"
375-450----4"-------3"
450-550---4.5"-----3.5"
550-650----5"------3.5"
650-800-------------4"
800-1000-----------4.5"
1000+---------------5"
Old Jan 3, 2003 | 12:30 AM
MdFormula350's Avatar
thats going to be one big pipe
Old Jan 3, 2003 | 01:46 AM
Kandied91z's Avatar
you have to be kidding..........i'm not running that size pipe on the car..
i've got that on my diesel and it's laughable large, i'll look like a lowrider shooting sparks down the blvd.:lala:
Old Jan 3, 2003 | 06:11 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
But NO ONE would tailgate you
Old Jan 3, 2003 | 11:04 AM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Well, get the biggest pipe you can fit in their.
Old Jan 3, 2003 | 11:46 AM
Kandied91z's Avatar
i know, i just hate the thought of it looking out of place...
Old Jan 3, 2003 | 12:22 PM
Z28DJP1987's Avatar
Stay with the 3" pipe...
Old Jan 3, 2003 | 01:04 PM
86 IROC's Avatar
Does anyone remember the metalic blue 91'-92' Z28 That was built by a magazine a few years back? It had a 420 with a super ram, Tremec T-5, etc. It ran into the 10's with a 3" SLP 2OL system IIRC. I wouldn't dump money into a larger exhaust until you have some sort of dyno proven proof that a 4" system will make enough of a difference to warrant the cost.
Old Jan 3, 2003 | 01:41 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Whooop there it is. Those numbers up top seem wrong to me. I've seen plenty an F-Body in the 11's with a 3" catback. Have also talked to an LT1 guy running low 12's with AFRs and a 224 cam who tried both a 3" and a 4" catback. No difference in ET between a 3" uncorked borla and the Mufflex 4" catback.
Tim
Old Jan 3, 2003 | 02:08 PM
Car: 99 Formula
Axle/Gears: 342
Tim
That's what I thought, I could have sworn 3'' single could support more than that HP, thus making the rest wrong, but I just copied and pasted what someone else did.
someone do some research.
Old Jan 3, 2003 | 02:29 PM
BRIrocZ's Avatar
Car: 97 Z28
Transmission: A4
I've seen that information before. Isn't it from Flowmaster
Old Jan 3, 2003 | 02:43 PM
Momar's Avatar
I dont know who the info is from or how accurate it is, but even if it is acurate it wouldnt be how much power you could make, it would probably be how much you could make without a noticable loss or something to that extent. I mean you could make a **** load of power with a 2.5 exhaust if you did enough stuff to a motor, but when you upgraded it your power would go through the roof.
Ben
Old Jan 3, 2003 | 05:22 PM
Car: 99 Formula
Axle/Gears: 342
Ben
I believe that chart or any chart for that matter, is based upon what HP there will be a restriction, so let's say you have about 400hp and a 3'' pipe, according to that chart above, you'd create more HP with larger pipe , so it won't be choked off.
Old Jan 3, 2003 | 07:09 PM
fastta's Avatar
I went from a 2.5 inch custom y and a full 3 inch single exhaust to a custom 3 inch y pipe and a full 4 inch exhaust this year and it with no word of a lie picked up close to a second on my et. I ran 13.9 with th old exhaust and then ran 13.20 without changing anything but the exhaust. So in my opinion it makes a huge difference.
With regards to hp ratings I know 3 people in particular that have small block chevys in the place I live in that run low tens and high nines with dual three inch exhaust.
So if the chart is right in saying that a single four flows as much as dual three inch, one can expect to go fairly fast with a four inch single pipe.
Keep in mind I'm not using a cat back system by mufflex buta full four inch single from the cat back.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
