Recommend a catback system for me
Old Jun 11, 2001 | 08:10 PM
One Eyed Jack's Avatar
Keeping a single catalytic converter, and under $300, I want a dual exhaust catback. Pick something for me.
1992 Pontiac Firebird (stock)
- 5.0L V8 TBI / Automatic Trans / Every option, excluding leather
- Killer car audio system:
  • Aiwa CDC-MP3 head unit
  • Rockford Fosgate 360a2 amp
  • pair of 12" MTX Thunder 5000s in a custom box
  • Pioneer 3-way 6x9s, soon to add more more more!
Old Jun 11, 2001 | 09:27 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
There is no dual exhaust cat-back for a single cat system, I don't even know if there is one for a dual cat system. Not in the aftermarket anyway.
You can but a regular cat-back from Hooker that is first class, and under $300. It's $259 to be exact from Jegs. Here's a picture.
http://www.jegs.com/images/products/52016810_large.jpg
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Jun 11, 2001 | 09:31 PM
No, I KNOW FOR A FACT there is
Im not talking true dual
Just dual outlets
Old Jun 11, 2001 | 09:44 PM
Engine: 4.0L
<font face="Verdana, Arial" size="2">Originally posted by One Eyed Jack:
Just dual outlets
</font>
I see now, you WANT a dual outlet cat-back. Why didn't you say so?
I still recommend the Hookers dual outlet cat back. I have it on my car and it is awesome. Do a search for "hooker" and see what the rest of the board says. You won't find one person un-happy with them I guarentee that. Price is right too.
Did you see the picture I linked in the second post?
86 Camaro Sport
My Camaro Project
Old Jun 11, 2001 | 10:46 PM
Old Jun 11, 2001 | 10:54 PM
Okay whats the difference between HO and non HO? My 305 TBI is what engine code?
Old Jun 11, 2001 | 11:46 PM
AaronK's Avatar
I think the HO stands for "high output". And your 305 TBI engine code is L03.
Old Jun 12, 2001 | 12:54 AM
Basett_Racing's Avatar
The TBI 305 (L03) falls under Non HO. The same as 82-87 LG4 4 bbl 305's.
82 Z28 383, Ported 215cc Dart Iron Eagle Heads 72 cc Comb. Chambers, Comp custom grind Hyd roller cam, Speed Pro .250" domes, Wheeler Motorsports 4340 I beam rods, Eagle 5140 steel crank, Weiand Team G intake, Holley 830 DP, hedman headers
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET:11.63 @ 113.25, w/ a 7.39 1/8 @ 93.04, and a 1.626 60'
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
New Best ET: 14.91 @92.9
Bassett Racing
Old Jun 12, 2001 | 03:29 PM
TransAm383's Avatar
Since you live in Michigan like I do, theres a way to save $60. Since we're in MI, we are not subject to emissions testing-so you really dont need that catalytic converter. Cut off the cat and order the system for the 305 HO($200 from Jegs). Cut off the first few inchs of pipe that would be right after the converter. Now just weld in a piece of straight pipe or clamp in a piece of flex pipe between the Y-pipe and the cat-back. Simple as that. Sounds like a lot of work but it isn't. You'll also get a louder exhaust out of the deal.
Old Jun 12, 2001 | 04:37 PM
RealDeal's Avatar
Sorry to interrupt the post, but what kind of a sound would that cat-back make? Closer to stock, or more like a lion growling under water(lol, that's the best comparison i could come up with)? Also how well would it work with a v6?
Old Jun 12, 2001 | 04:39 PM
RealDeal's Avatar
'91 Camaro RS (Purple!)
K&N Filter
Awaiting my Twin Turbo Hood and Flowmaster.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Fronzizzle
Feb 9, 2017 09:31 AM
Logan Bryant
Sep 18, 2016 09:27 AM
Loudnproud86
Jul 14, 2016 12:59 AM
Hello, Michael
Sep 11, 2015 01:10 PM
