which restricts more?
Old Jan 25, 2003 | 04:07 PM
Killogy's Avatar
Car: 87 Firebird Formula
Engine: 355
I just had my catback put on finally and my car seems really really slow. But I have it 3" all the way back until the muffler which is only 2.5". I already ordered a new 3" muffler. I'm just wondering what would clog up my system more. A catalytic converter or a crappy muffler? Cause I really don't wanna change the cat since its all nice and welded up.
Old Jan 25, 2003 | 09:30 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
3''all the way back? yet a 2.5'' inlet to the muffler? That right there is your restriction, an exhaust system is only as good as it's weakest point..
Old Jan 26, 2003 | 01:15 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
if the cat is original it is prolly time for replacing or removing
Old Jan 26, 2003 | 01:28 AM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Looks like it's time to gut the cat....
That's one good thing about living in Indiana, no emissions testings so we don't have to have cats...
It's either that, or you have a really crappy muffler.
Old Jan 26, 2003 | 01:11 PM
MdFormula350's Avatar
i would think muffler also..
what cat are you running? could of clogged up for some reason.
Old Jan 26, 2003 | 05:49 PM
Killogy's Avatar
Engine: 355
Its a brand new cat. But I have a 3" muffler on the way. So once that comes in I'll find out if its my problem or not.
Old Jan 27, 2003 | 05:56 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
If your using the flowtech y-pipe the collector would be another if not the biggest resriction.
Old Jan 28, 2003 | 09:23 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
It is more important to have the larger, free-flowing system close to the engine than it is to have it back at the muffler. That is because exhaust is not a constant flow but a series of pulses. The 3" intermediate pipe will act as a plenum to "collect" the pulses so they can still flow out of the 2.5" muffler without a significant effect on power.
A cat will cause about a 5 HP or less loss. You'll lose that much power when the temperature goes from 60 degrees to 85 degrees. The cat does a good job of cleaning up the exhaust, so be a responsible citizen and keep it in there.
As to what I did myself: I used a high-flow 3" cat, like you. My cat-back is the Pace Setter system from JC Whitney. The I-pipe and tailpipes were fine, but the muffler inlet was 2.5", expanded to fit the 3" I-pipe. I quick ordered a 3" inlet Flow before installing the system.
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Zell1luk
Sep 29, 2015 10:36 AM
BWilcox
Sep 20, 2015 12:19 PM
ericjon262
Sep 11, 2015 06:07 PM
