just got headers, i need some help!!
Old Jan 28, 2003 | 09:18 PM
bad_ta_05's Avatar
Car: 85 trans am
Engine: 79 4 bolt 350
i just got my headers today, they are flowtechs and i got them installed pretty easily along with the y pipe but i cant get the last bolt in on the passenger side header, i just cant fit my fingers in there. any advice? also my y pipe is 2 1/2 (i think) and so is my cat so i cant fit the y pipe into the cat. i already gutted the cat and ran a strait pipe through it. could i just notch the cat and spread it out a bit and slip it over the y pipe?? i thought about running a strait pipe instead of the cat but i dont think ill find one that will slip over the y pipe and fit inside of my tailpipe. can anybody help?
Old Jan 29, 2003 | 12:26 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
go from the bottom, have you tried that? better get good cuz you are prolly gonna need to tighten that bolt from time to time....
Old Jan 29, 2003 | 03:07 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
That is a tough bolt to get at. Try to get someone with small hands to try it. Then you might need a couple of open end wrenches with different offsets to tighten it up.
Old Jan 29, 2003 | 03:13 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
sounds like the best advice I've heard, if for some reason underneath still won't work for you, I found that when I removed my AC box on the firewall, that cleared up a TON of room. You can reinstall it if you want, but I left that sucker out.
Old Jan 29, 2003 | 06:17 PM
bad_ta_05's Avatar
Car: 85 trans am
i tried going from the bottum and it didnt work, after about an hour and a half i FINALLY got it started today, but now i cant get to it to tighten it! i looked an i have no clue how to take off the a/c box, i wanted to but i dont even know where to start, any help would be great. i removed most of the a/c stuff except that.
Old Jan 29, 2003 | 06:22 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I have the same headers, and I got to it by running my arm through the space between the #4 & #6 headers. I had to use the open end of a shorty wrench to get on it.
Old Jan 29, 2003 | 08:26 PM
Car: 99 Formula
Axle/Gears: 342
Also, I don't know the name of the tool, but it's a wrench that is closed but it has an angle to the handle. kind of hard to explain, lol.
_O
_ |
O
Kind of looks like that. good thing I'm artistic
Old Jan 30, 2003 | 07:46 AM
Blackroc86's Avatar
Car: 1986 Iroc
Thats what I mentioned in my earlier post. He may need a few flat wrenches with different offsets (angles) on the jaws. Maybe a half moon box end would help as well.
Old Jan 30, 2003 | 08:15 AM
Car: 99 Formula
Axle/Gears: 342
_O
_ |
O
LOL, that didn't come out how I typed it.
Old Jan 30, 2003 | 03:44 PM
bad_ta_05's Avatar
Car: 85 trans am
well, i finally got it all good and i found a little bitty wrench that worked and everything and then i realize that the gasket slipped out! so i said screw this and saturday im going to buy a set of good gaskets that just drop in. and im taking my cat to a guy and he is going to cut it down and weld on a bigger pipe that will go over my y pipe, so hopefully its all coming together.
Old Jan 30, 2003 | 09:34 PM
i have removed the box and can change all 8 plugs in under 10 mins, and i can tighhten the bolt you are talkign about with a ratchet. get that bolt as tight as possible with your hands tho, it will save time
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
