Single to Dual Cat Conversion
Old Jul 30, 2001 | 01:19 AM
mult68's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
I have a single cat right now...will be getting SLP 1 3/4" Headers.....I need some breathing room as well as not having to worry about passing the sniffer test..so I thought that dual cats would be the way to go...Im guessing I need to get the SLP Dual cat headers....but what else will I be needing? I heard that SLP doesnt come with the actual y-pipe...just the connections to the y-pipe...could i just have an exhaust shop make one up for me? And how do I mount the extra cat? and what about the extra AIR tube? Where Do i get all this stuff? THanks
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
3" Flowmaster Exhaust System w/Quad Tips
Aiwa CD/Mp3 player
10 Disc CD Changer
Rockford Fosgate Speakers
SLP Headers Coming
Dynomax High Flow Cats Coming
More to come.
Old Jul 30, 2001 | 02:45 PM
Mo's Avatar
Mo
the SLP headers don't come with the actual y-pipe, they come with pipes that go upto the cats, you could have a shop can make the y for you. What happens with the air tube is it starts out as one tube and then goes into this little piece and comes out as two tubes, a shop could pry handle that too if you couldn't find any parts anywhere.
90 IROC 5.7l (L98)
ram air, K&N's, air foil, full exhaust
LIKE A ROC
http://members.nbci.com/IrocZgarage/home.htm
Old Jan 29, 2010 | 11:02 PM
Lampropeltis's Avatar
Car: '89 Flame red metallic GTA!!
Re: Single to Dual Cat Conversion
So not too satisfied with the answer to this so far. There is another thread somewhere in this section where someone actually compared their track times with both single and dual cats and consistently pulled markedly better times. So I am sold and converting. My question is, where do I find the air tubes and y pipe to convert my L98 from a single cat to a dual cat car.
Old Jan 30, 2010 | 02:07 PM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
About 5 yers ago I got the Catco direct replacement setup for my 91Z. It was a sweet setup for decent price. It goes from the manifolds back. I ended up cutting the Y-off and used the flowmaster Y collector. I did this cause I welded a flange to the Y collector and flanged the SLP loudmouth catback. This makes it easy to pull the exhaust.
Old Feb 11, 2010 | 04:59 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
I have a dual cat car ill post up some pics for you, as im cutting mine out shortly in favor of some cheap edelbrock 68722 ceramic headers... aka going single cat/ test tube for now...
Old Feb 11, 2010 | 07:21 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
had to dig up a 9 year old thread for this?
Old Feb 11, 2010 | 07:53 PM
Stephen's Avatar
Car: 87 GTA
With a quality aftermarket converter, there is really no need for dual cats. Un less you have a SERIOUS engine that truly needs the extra airflow. Otherwise, all your doing really, is adding extra weight to the car.
Old Feb 12, 2010 | 09:43 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Wow! I didn't know that.....those damn GM engineers got me again.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
PurelyPMD
May 5, 2016 04:57 PM
customblackbird
Oct 1, 2015 04:30 PM
Camaro_383
Sep 11, 2015 11:28 PM
