DUAL EXHAUST!
Car: 1988 Mustang GT
Engine: 302
DUAL EXHAUST!
Dual exhaust on a fbody? all you have to do is take around 4 inch diameter pipe and ovalize it down.... flows the same and sounds SWEET
Why "ovalise" it yourself???? As soon as you hit the first bump in the road it will be ovalised, then it will fall off, then the sparks from all that metal dragging will burn your car up. I guess then you can get a 1 gen Camaro and put true duals and get away with it
Just my thoughts..
Just my thoughts.. Senior Member
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
I've got a true dual exhuast setup I wouldn't think of not going with it in a performance setup.
383 86 Camaro Z28
10.5:1compression Dart Pro 1 Aluminum heads 215cc>2.05/1.60 valves,400 steel crank,cam specs:224/234 at 050 525/525 lift,2500 stall converter,shift kit,3.42 gears,770 Holley Avenger,Victor Jr. Intake,true dual exh,Hooker headers with 40 series Flowmasters,MSD Coil and Module.
383 86 Camaro Z28
I have a dual 3in setup, I need it. I like it. The car is mine, so I'll do what I want with it. Wait a minute...don't ricers have single exhaust??? That makes all cars with single exhaust Rice...I hate that stupid term, most of the guys who use it are probably pissed cause they got whipped by one. OK, I am done venting now. Have a nice day
Black 89 IROC...355, Solid Crower Cam, TFS heads.
12.0 @ 120.3mph with a 1.9 60ft...all motor
I have dual exhaust from the manifolds back to dual tips. I haven't done ANY exhaust work but there are 4 glass pacs (two small 'resonators') and dual H-pipe. My car has an unexplained amount of power for a 305 and I'd attribute it to the exhaust and gearing.
1985 IROC-Z, nuff said :P
i, too, had true duals on a 305 3rd gen. except for the hedders and a performance-rebuilt carb, everything was stock. that car flew
fyi- i'm having true duals run on my current 3rd gen tomorrow AND i'm replacing my "high flowing" 3in after cat!!
fyi- i'm having true duals run on my current 3rd gen tomorrow AND i'm replacing my "high flowing" 3in after cat!! Trending Topics
Car: 87 GTA
Engine: 355 Chevy
Duals is the way to go! Ive got hooker 1 3/4 super comps and dual 3" flowmaster exhaust on my 87 T/A. Talk about power increase!! It picked my car up .3 in the 1/8 over 2.5" duals 1 5/8 shortys routed factory location.. Anyone who takes a little time to think about flow characteristics on the factory f-body exhaust would realize that GM really fubared our cars from the factory. put duals on a stock tpi and watch the mustang boys scatter!
So to run Duals, what do you do about the O2 sensor, do you use a crossover or whatever they're called, and are there bullet shaped cats?
Pretty new to this stuff, so any answers you could give me would be much appreciated.
I am planning on doing a true duel setup in the next couple weeks, I'd love to know your guy's different setups and how you did it.
I plan on just running hooker shorty headers and then just running the pipes (2.5") straight back and two mufflers dumped right in front of the axle...
any thoughts (other than "you cant do it") ?
Car: chevy s10,1986camaro
Engine: 406sbc
Transmission: 350turbo
Had Dual 2 1/4" and single 3", the car had a lot more go to it with the 2 1/4" setup. On wensday I'm getting my dual 3" with flowmasters put in not sure what kind of ground clearance I'll have but I'm willing to sacarfice it for the extra power, and the sound.
406SBC
-DART SPORTSMAN 2 HEADS
-RPM INTAKE
-750 SPEED DEMON MECH SEC. CARB
-HEDMAN HEADERS
-COMP CAM EX .507/.510
406SBC
-RPM INTAKE
-HEDMAN HEADERS
<font face="Verdana, Arial" size="2">Originally posted by sb406camaro86:
</font>
</font>
Thats what I'm saying, who cares if I lose 1/2 an inch or even an inch of clearance? Not like I'm going to be driving over speed bumps or up drive-ways all day....
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
on a dual exhaust setup, where on the car is clearance a problem? Behind the transmition right? how about raising the backend about 2"? hardly noticible but would make for more clearance?
what about exhaust equalization? my muffler guy when I asked him about duals said, it wont work because there is no way to connect the two pipes to equalize the exhaust backpressure which can hurt performance!?
Car: 87 GTA
Engine: 355 Chevy
<font face="Verdana, Arial" size="2">Originally posted by Jer82Z28:
</font>
</font>
1987 GTA 355, carbureted, TFS heads(non G2), 6-speed, McLeod clutch, 11.3:1, dual 3" flowmaster 2-chamber exhaust with NO tailpipes, 98 z-28 wheels, soon to be replacing weak 10 bolt with 12-bolt...gettin tired of breakin axles....
...Whatever turns your tires.....
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
