Lt + A.i.r. ???
Old Feb 14, 2003 | 08:37 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Lt + A.i.r. ???
I am sure this has been covered many times...so i am sorry,but the search doesn't work
does any company make long tubes that are smog freindly with air tubes?
OR how hard would it be to retro fit a pair of long tubes to have air tubes?
also i would prefer 1 5/8" primaries.
Old Feb 14, 2003 | 01:36 PM
Momar's Avatar
No one makes them. I dont know how hard it would be. I would imagine that you would basically have to drill the holes and weld the pipes in and bend them how you wanted. If you want 1 5/8 go with hedman lt headers. They are only a little over 100 bucks too.
Ben
Old Feb 14, 2003 | 01:47 PM
Dewey316's Avatar
Car: 1990 Camaro RS
looking at the factory air tubes, i wonder if i could jsut drill and tap the headers, and screw those in
Old Feb 14, 2003 | 01:49 PM
Momar's Avatar
It might be possible because there should be one at each primary exhaust port right? If so it might be possible.
Ben
Old Feb 14, 2003 | 01:57 PM
Dewey316's Avatar
Car: 1990 Camaro RS
what we need is someone with those headers to measure the distance from the center of each primary. then i could measure the factor tubes, and see if it might work.
Old Feb 14, 2003 | 02:01 PM
Momar's Avatar
Well, the distance between the primarys should be the same as the distance between exhaust ports on a set of small block heads if you happen to have a set laying around or something. If not quite a few people have them, but I have hooker lt's myself.
Ben
Old Feb 14, 2003 | 02:16 PM
Dewey316's Avatar
Car: 1990 Camaro RS
for 100 bucks i might just get a set of those hedmans, and see if the tubes will fit :shrugs:
BTW i woudl get the hookers but they seem to tonly have 1 1/2 and 1 3/4" i would like 1 5/8s for my 305.
Old Feb 14, 2003 | 02:43 PM
Momar's Avatar
The hedmans are supposed to be decent headers. I just wanted the 1 3/4 for my 350, plus in the future I would like to gain even more cubes and go to a 383 or 406.
Ben
Johnny*G
Oct 20, 2015 12:37 PM
myinvestedagony
Jan 29, 2002 04:15 AM
Inwo
Dec 1, 2001 04:32 PM
Inwo
Dec 1, 2001 11:57 AM
XLcIROCZ
May 25, 2001 09:34 PM
