Smoke!!
Old Aug 17, 2001 | 08:10 PM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
Smoke!!
Hey guys, i have an 88 iroc Z28 convertible and have a little problem with my exhaust. I just recently bought the car a week ago and have noticed that there's white smoke coming from the tips constantly. At startup it's visible, but eventually it dies down to the point where u have to look a little harder to see the smoke but it's still there. Any ideas of how to fix it? I was thinking maybe the oil needs to be changed, which I was going to do next week sometime, and if that wouldn't work then what could it be? any help will be appreciated, thanks
Old Aug 17, 2001 | 08:36 PM
Tas's Avatar
Tas
I think white smoke is coolant getting into the chamber. I hope its only a bad gasket and not a cracked head or something. Go ask on the general tech board.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Aug 18, 2001 | 12:09 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
If its coming out ALL the time, that dosent sound too good
Id defently post in the general board. You will get alot of help!
1988 Jet Black IROC
5.7L W/ 64000 miles
Flowmaster Exhaust
Fully Loaded
My IROC
Old Aug 18, 2001 | 02:21 AM
rezinn's Avatar
Does your exhaust smell sweet? Are you losing coolant, car overheating? You should do a leakdown test. You may get to take your heads off.
Old Aug 18, 2001 | 02:24 AM
87tpi420's Avatar
smoke at all(white) means water/coolant is being burned. check your oil and see if it is creamy colored after its running) also check your coolant.more than likely it is a gasket, but could be somthing worse. check it or get it check to make sure! it does not apply but i had to replace a $10,000.00 diesel engine because of bad oil/ coolant in it. just do a rad pressure test, i think that will cover it.........but not positive! (im ****ed now at 3 am)
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
Old Aug 18, 2001 | 07:28 AM
nikh23's Avatar
Ok so how do i perform these tests. The car was actually low on coolant when i bought it and put some more in earlier in the day. Could it be possible that the coolant still hasn't gone through the engine yet because the car sits in my driveway due to lack of plates and i only start it in times of need. But if thats not it could someone explain how to perform the tests or a website/manual that does? thanks guys, been a great help
Old Aug 18, 2001 | 10:58 PM
Bad Blk Z's Avatar
If you have a 305 in your car you can just calm down. I have yet to see a 305 that doesnt smoke. All the valve seals leak all the time thats what the smoke is. trust me. Try changing your oil to synthetic it will help the smoke cause synthetic doesnt burn.
Old Aug 18, 2001 | 11:43 PM
nikh23's Avatar
Ok that soothes me a little, the car is the 5.0L TPI 305. The previous owner SAYS he put synthetic oil into the car in November, but I'm going to change the oil and oil filter to Mobil 1 synthetic and K&N def before the end of the week. Can i still pass emissions testing with this smoke? thats the real concern that i have
Old Aug 19, 2001 | 12:19 AM
87tpi420's Avatar
hey bad... if it smokes all the time even? as he stated? normally if the seals leak it gives a cloud at startup, but goes away when all the oil is burnt off. and if it was oil smoke would it be a bluish color? or greyish? but white is water isnt it? pretty sure it is. i am no genius though!
http://people.ne.mediaone.net/gdm
FormulasOnly
Jul 23, 2018 08:47 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
KCG
Sep 23, 2015 09:05 AM
Accerrito22
Sep 5, 2015 09:34 PM
