Tip question... they affect sound and tone -that- much?
Old Sep 8, 2001 | 10:06 PM
Xenodrgn's Avatar
Ok, first... my set-up... I have what i believe to be a Mineke (sp?) stock replacement muffler... the tips are about 16-20 inches long (enough to extend to right underneath the bumper) however they are bent down and cut at an angle... This set-up is quite quiet for a thirdgen, and pretty quiet even for a V6... Recently my right pipe has come loose at it's joint to the muffler, and it's gotten louder... a nice grumble and has become noticeable in the car...
My question is this... what different kinds of tips affect the sound and tone in what way? What could I do to project the loudest sound outside the car? (aside from putting a coffee can on it...) Should I cut them, angle them down, leav them straight, make them long or short?
Any suggestions and answers are appreciated.
1985 Camaro SC - 2.8L, auto.
http://www.xenodrgn.f2s.com/Frontright.jpg
Old Sep 8, 2001 | 10:12 PM
TOPLESZ's Avatar
Car: 2002 Camaro SS
Transmission: 6 speed
Axle/Gears: GM 3.42
a friend of mine put a Dynomax cat back on his 2000 GMC pickup...the kit had dual 2 1/2 pipes on it (coming straight out under the bumper) and it sounded really loud and mean. I had an extra set of those Hooker chrome dual tips that I gave him...after bolting them on it COMPLETELY CHANGED the tone from the mean bad *** tone to a more nasally growl tipe of sound.
So, yes...the tips can make a HUGE difference.
1992 25th Anniversary z28 Convertible
Old Sep 9, 2001 | 12:28 AM
BahamutRS's Avatar
Rarely do they do that..I mean, if you have the Borla ones or something, maybe, but why not just put a performance exhaust on? Even a V6 would benefit with a little more pep...
1992 Camaro RS (Auto) 5.0L TBI
Performance mods
NOS (125 HP shot)
Dynomax cat-back exhaust
Hedman headers
K & N open element/ X-Stream lid
MSD 6A ignition
LT1 camshaft
Soon to be installed:
Edelbrock intake manifold
3.42 rear axle
B & M 2400 RPM stall torque converter
Transgo shift kit
Moroso Blue Max plug wires
Torquer heads
Audio
Sony Xplod CDX-M610 head unit
Pioneer 2-way 4x6 front speakers
Pioneer 3-way 6x9 rear speakers
12 inch Pioneer VCCS PRO subwoofer
QLogic sealed box
Kicker ZR360 amplifier
Lightning Audio 1 farad capacitor
Other
Macewen White Faced Gauges/Shift overlay
A-pillar gauges (Phantom oil pressure, Air/Fuel)
180* thermostat
Window Tint
Old Sep 9, 2001 | 12:46 AM
breathment's Avatar
i have a theory which i will see if its correct or not tomorrow. If putting on dual 20"x3.5" tips over having 2.25" tips will improve the sound. i'll take pics!!!! and i'll try making an MP3 too..
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
Old Sep 9, 2001 | 01:50 PM
Xenodrgn's Avatar
My theory is that wider the muffler-back pipes are, the louder the tone is... however if you don't have enough airflow the sound will become rice-ish above 2500RPM if the tips are too short and/or wide...
Today I lost my one pipe on a highway going to my girlfriends, by the time I could turn around and get back there, the pipe had been run over several times, rendering it completely useless...
The sound from inside the car is a huge grumble, the side of the vehicle is the same, but behind it... it's not -that- much louder...
Yes, I know about performance muffler set-ups and such, as soon as I get some dough (and get my engine mods done), I'm going to get a Super Turbo muffler, and have someone bend and cut me new tips for it... My cat-to-the-muffler pipes are just fine, the same size as the Y-pipe conjunction pipe... going any bigger than that would be a useless waste of time and money... I'm going to order the dual out 2.5's...
Thanks for te insite... hope this post helps -someone- out...
Old Sep 10, 2001 | 12:06 AM
formula14's Avatar
ive got a quick question about my s-10 blazer. I just put a 50 series flowmaster on. 2.5 inch. i just have a pipe coming out like 16 inches behind the muffler. the pipe stops a few inches before the rear axle. It is actually kind of annoying loud in the car but it sounds great outside. If i had a shop make me pipe to the rear of the blazer will it be alot quieter inside but still sound really good outside. or will the longer pipe take some of the growl out of it.
Old Sep 10, 2001 | 12:21 AM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
Yes, the pipes comming out of the mufler, how they are angled, and how long they are do matter.
Example: I bought a flowmaster for my car, but i wanted a sertain sound out of it. I wanted to be loud outside and as quiet as a can get it inside. so what i did was i took to long pieces of straight pipe and cut them off 2 inches from the end of my bumper, so now it very loud outside but soft inside.
A down angl pipe will channel the sound downward so it will be softer then straight pipes.
If you want a loud interior sound cut off the pipes like 3 inches short of the bumper, in won't be very loud outside but it will rattle you inside.
Just thought this might answer your question.
Robert
Chevy 2.8L 60° V6
Mods:
?K&N Filter Lid
?87 Formula Hood
?Bosch Platinum +4
?Hi-Flo CatCo CAT
?Flowmaster 80 Series Muffler
?83 Trans Am 15x7 Turbo Fin Wheels
?B.F.Goodrich Radial T/A 225/60-15
?Chevy 2.8L Heddman Headers (Going on soon)
Aol instant messenger: FIREAM
http://www.geocities.com/fiream/RobsCarArtPa.html?994187591828
Old Sep 10, 2001 | 02:52 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I just changed my tips from the crappy chrome ones that come with the hooker cat back to some borla ones. The car sounds the exact same to me. I thought there might be a change because the outlet size went from 3" to around 2.5" (because of those pattented borla flange thingy's). Now a turn down tip might make a diff but I am not sure.
1990 RS 305 TBI T-5
.5" turbocity spacer
Edelbrock TBI intake
180* stat
Summit 14X3 OpenElement W/k&N
Hooker 3" Areochamber
MSD - Wires, Cap, Rotor, Coil
Bosch Platinum +4 plugs
Metallic Red w/28,000 Pampered miles
(Still have the original wiper blades)
Old Sep 10, 2001 | 04:18 PM
breathment's Avatar
<font face="Verdana, Arial" size="2">Originally posted by fiream:
</font>
Ya, right now i have my 80 series, and i haven't finished putting on tips, so the exhaust exits about 16" before the bumper, loud in the car, not so loud outside, hopefuly it will change when i put on the new tips.
- David
88' GTA 5.7L TPI MODS---&gt; air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
Old Sep 10, 2001 | 09:31 PM
breathment's Avatar
alright, i brought the tips tonight, and test fit them, no clamping or anything, but anyways, i did a little PRE test to see how they souned on, and to tell ya the truth, no to different. 16"x3.5" chrome pics, i'll try to have lots of pics tomorrow. and the final results
- David
Old Sep 10, 2001 | 09:41 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
My 80 series is loud inside and out, couldnt be happier
1988 Jet Black IROC
5.7L W/ 64000 miles
Flowmaster Exhaust
Fully Loaded
My IROC
Old Sep 10, 2001 | 10:01 PM
breathment's Avatar
<font face="Verdana, Arial" size="2">Originally posted by IROCThe5.7L:
</font>
do u have any other exhaust upgrades? such as gutted cat or y-pipe? i guess i'll just have to wait and see how it sounds in a few months. GEEZ, well when i goto the swap meet this weekend, maybe i can ask some people how it sounds and stuff.
- David
Old Sep 12, 2001 | 11:49 AM
89FormulaL98's Avatar
i have no clue how any body could complain about the 80 series as far as being loud. on my car it was loud inside and out under about all conditions.
Old Sep 12, 2001 | 12:52 PM
Car: 1988 IROC-Z
Engine: 427 SBC
[/b]
[/B]</font>
My car is bone stock except for 3 inch pipe
from cat to muffler. Thats it.
1988 Jet Black IROC
5.7L W/ 64000 miles
Flowmaster Exhaust
Fully Loaded
My IROC
[This message has been edited by IROCThe5.7L (edited September 12, 2001).]
Old Sep 12, 2001 | 04:30 PM
breathment's Avatar
alright, im gonna begin testing the tips today!!
- David
Old Sep 14, 2001 | 01:56 PM
Xenodrgn's Avatar
Thank you all for your advice/opinions/facts... It's really helped me out to decide what I wanna do to my exhaust.
Old Sep 14, 2001 | 02:38 PM
OldBlue's Avatar
well I will say this. you ever hear any of the big semi's ( kenworth, peterbuilt, freightliner, Marmon ) some of them you can hear from a half mile away look up at their stacks. if you ahve a 45* bend, staight cut or angle cut will change the sound. Straight is by FAR the loudest. we have a fleet of 8 trucks two of wich are Kenworth t-600's with 600 catapilar engines in em. they are both the same year same set up everyting BUT one has straight pipes and one has a 45* bend and angle cut. there is such a differnce in sound youd think it has a 570 or maybe even the 400 cat instead of the big 600
Hotrodboba400
Dec 10, 2019 07:07 PM
Blue419
Sep 10, 2015 01:03 PM
89fast5oh
Sep 8, 2015 09:55 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
