Long-Tube headers?
Old Sep 3, 2001 | 04:32 PM
JcmIROC-Z's Avatar
Long-Tube headers?
Does anyone make Long-Tube headers for 3rd gen TPIs?
89 IROC-Z with 350 TPI
1 3/4" SLP Headers, 3" mandrel bent pieps with high-flow cat and flowmaster, K&N air filters, Sony Xpold CD player, 17" chrome ZR1s
Old Sep 3, 2001 | 05:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Strictly speaking, the answer is "no".
Because you said "for 3rd gen TPIs". Running long tubes into a y-pipe to get the gases to the convertor in the stock location (required for "TPI" EPA-legal exhaust) is a custom job.
So, yes, long tube headers are available; but, they aren't "bolt-ins".
Your SLP's are pretty good pieces. Long tubes wouldn't increase your performance enough to justify the cost & hassle.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" cat-back, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Sep 3, 2001 | 08:38 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Hooker makes long tube headers for thirdgen TPIs. Although they are made to 'fit' thirdgen V8s (including TPIs), they are not emissions compliant. Fitting TPI engines and being emissions compliant are 2 different things. Along with a mufflex Y-pipe the system is a bolt-in .... albeit a hard one.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
[This message has been edited by TRAXION (edited September 03, 2001).]
Old Sep 4, 2001 | 02:25 PM
Phil87IROC's Avatar
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
Yep, but like Traxion said, it's a tough install. Here's my setup:
http://www.geocities.com/cfrios/Phil...l?996948051310
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190 heads, TPIS ZZ-9 cam, Edelbrock RPM intake, 1" TD spacer, Hooker SC/LT headers w/ Mufflex Y-pipe, Edelbrock 750 cfm Carb (#1411), Stock T-5, GM 3.42 gears w/Auburn posi.
Ohio Valley Dragstrip (KY) Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, TES w/Flowmaster, 1LE DS, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hypertech Chip, gutted MAF & CAT, Jacobs Ign., 53kv coil, MSD wires.
Old Sep 9, 2001 | 11:09 AM
86 IROC's Avatar
I have to dissagree about the lack of performance difference between long tubes and shorty headers. But, on a stock/near stock engine - it might not matter much. However, on a large cubic inch - or modded 350, I'm willing to bet that long tubes are worth 20-25 HP @ the flywheel compared to shorties - as long as they are both the same primary tube size.
I put 1&5/8 long tubes on my friends 95 GT, it went a best of 12.959 @ 105.84 w/ 1&5/8 equal length shorties. With nothing other than the BBK long tubes, it went 12.707 @ 107.1 I'd say that is a nice gain.
1986 IROC, fully loaded, Mini Ram'd 383, Art Carr 700R4, Accel DFI, 12 bolt rear, etc, etc......
Old Sep 9, 2001 | 12:12 PM
five7kid's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 86 IROC:
</font>
Unless Jcm has mods not in his sig, I wouldn't call his "highly modified" (other than the headers, the only mods are air filter and stereo). Thus, my comment.
Most 12-sec cars are already "highly modified". A 2-tenths gain is indeed significant there, but even as you said, you're not likely to get that in a daily driven, emissions legal ride.
Old Sep 16, 2001 | 01:01 AM
b92z28's Avatar
just to let you know heddman also makes long tube headers for 3rd gens. but they are 1 5/8 primaries versus the 1 3/4 for the hooker. both have a 3 inch collecter.
Old Sep 22, 2001 | 12:35 PM
Formula-91's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Phil87IROC:
</font>
How much ground clearance do you have?
Old Sep 22, 2001 | 09:14 PM
Phil87IROC's Avatar
Car: 1987 IROC Z28
My ground clearance is a little less than before the Mufflex y-pipe. I have scraped it a bit on a sharp dip in a road going 50 mph. I have to be aware of this as I approach speed bumps and sharp inclines.
It's totally worth the extra performance and the sound is simply awesome. My 383 with this exhaust turns heads everywhere I go........one of the best mods I've done to date!
It's not for the 'mechanically disfunctional' sort nor is it for the 'emissions-minded' hot rodders!!
Phil87IROC
Old Sep 23, 2001 | 12:53 AM
85 Berl's Avatar
I don't understand why it's not legal to have long tubes, and 2 cats the same distance from the engine. I just don't get it.
Jeff
'85 Berlinetta, Special Beater Edition
Mods include a 4bolt 350 with 280*, .460 lift cam, Vortec heads, Comp Cams roller tip rockers, Edelbrock TES headers, no other exhaust . Also, rusted parts on all 4 corners, and crumpled fenders, thanks to the previous owner.
Old Dec 25, 2001 | 08:55 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
how easy would it be to install some LTs on an car while the engine is out, i may be pullin my engine soon and would like some long tubes but is there any modification to the floor pan or starter or anything or is it all exhaust
Old Dec 25, 2001 | 09:49 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
Hey Phil,
I've seen your pictures, but since you did it maybe you could tell me.
Do you think there is room anywhere in that setup for a cat?
I thought maybe right after the y pipe in the driveshaft tunnel.
What do you think?
Old Dec 26, 2001 | 02:44 PM
Ray Burrows's Avatar
Phil..... What part hits the road when you scrape? I assume it is the Mufflex Y pipe, near the transmission support bar?
Old Dec 26, 2001 | 11:54 PM
Phil87IROC's Avatar
Car: 1987 IROC Z28
Fake: My muffler shop showed me some 'new' Random Technologies 'shorty' 3" CATs that could be mounted on the y-pipe on the two pipes after the collectors. They flow nicely. The mufflex y-pipe exits with a 4" pipe. I have never seen a 4" CAT. It would be restrictive to go down to a single 3" CAT then a muffler. I don't use or need them though so I have done little investigative work here..............
Brody: I installed my LT headers with the engine out too. Twice. You can't put them on the engine then drop the engine in, no way, at least not with these Hooker model 2210s. Not enough clearance on either side. I lowered the motor to just about 3" above the motor mounts then worked the headers on from underneath the car. The pass side is the toughest due to the starter and dipstick. You need to work the starter in as you position the pass header, it's tough. A small Hi-torque starter may solve this problem. I also recommend getting them coated due to high heat output and to get 'angled plug' heads. I have to make my spark plug (shorty) for cylinder #7. My AFRs are straight plugged. Only #7 plug is a problem. I also had to dimple the headers in two spots where they rubbed on the frame of the car on the pass side. I just did my pass side today. What a job! Bottom line, I DO NOT recommend LT headers for anyone who is impatience or can't wrench on a car very well or has annual smog inspections. The SLP 1-3/4s will work fine. This LT install is tough. This was my 12th header installation on over 10 different cars over 15 years time. I've learned to have patience!
BERL: As far as smog, I don't think Hooker offers the SC LT headers with AIR tubes. CATs can be installed though.........
Ray: Yep, y-pipe near tranny x-member.
Hope this helps gents................
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
