egg like smell?
Old Oct 17, 2001 | 03:27 PM
1982chevycamaroz28's Avatar
egg like smell?
the other day i finished with my hookercatback and a catco cat. it smells like roten eggs and it smells kinda rich. will this smell go away after the cat is broken in. and how could i lean out my stock qjet. please help me.
mods to car
new ignition system, edelbrock intake,600 cfm q-jet,th-350 tranny, used black interior, grant stering wheel, accel plugs and wires, hookercat back, b&m shifter, emmission delete package, computer delet package and soon ac delete and in future-- hooker sump comp headers, posi rear, drag slicks and all new rims probably weld rims, line lock, 8 point roll cage, strut tower brace, drag shocks, sfc, new edelbroc 600 carb, nitrous and a weiand supercharger or a 350 or 400 block
Old Oct 17, 2001 | 04:21 PM
F0xBody50's Avatar
Yeah, that's normal...
I just got my new exhaust system and it put out a burning smell that diminished after a week or two before it was broken in...
The systems have preserve chemicals sprayed on em to prevent rust and corrosion, and when you drive with the new exhaust, it burns up those chemicals, enjoy your new system!
-ONE2FLY
1990 IROC-Z Camaro
Artic White w/ Gold Decals, 305cid V8 TPI, 700R4 Auto w/ OD, 16" 1992 Z-28 rims (w/ white trim), Z-rated Extremos 245/50/16s (new), Power Options, T-Tops, Tinted Windows, Flowmaster Exhuast w/ High-Flow Cat-Back....
Old Oct 17, 2001 | 05:09 PM
also with it brackin in will it give like that little bit of like white some but its not smoke its almost like when u start the car in the mornin it has like a little bit of white gasses or smoke comin out is that aso the system breakin in.
mods to car
Old Oct 17, 2001 | 06:42 PM
F0xBody50's Avatar
Yes, that "white smoke" is actually mostly steam coming from the catback, I noticed alot of it when my system was new, it is also normal and will lessen with time...
You may also notice a litte water coming out of your pipes, either in normal driving or if you rev your car, that's condensation and is normal with performance exhaust systems...
-ONE2FLY
1990 IROC-Z Camaro
Old Oct 17, 2001 | 08:47 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I had the same problem after I had the cat-back and new cat installed. It's starting to go away.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Oct 18, 2001 | 11:43 AM
hey thanx guys but also if i take it to inspection and it has that steam comin out what should i do becuz i know if they see visable smoke or anything the'll fail u. well thanx anyways guys
Old Oct 18, 2001 | 01:04 PM
F0xBody50's Avatar
Wait for your system to break in a bit before going for inspection if you can...
The only time I ever really see the steam is in the morning or evening when the air is cooler outside, the amount should go down as your system gets broken in...
Do they really fail you for putting out steam? I find that hard to believe...
-ONE2FLY
1990 IROC-Z Camaro
Old Oct 18, 2001 | 03:11 PM
yea they fail u for visable smoke or anything that isnt suposed to come out of the tail pipe. i think ill just call like dmv or someone that i could ask if that could fail me. if so i think i just might call someone to get me to pass
mods to car
Twin_Turbo
Mar 14, 2016 10:10 PM
Dwayne614
Sep 29, 2015 11:05 PM
Racerx974
Sep 19, 2015 10:16 AM
earlpote
Sep 12, 2015 11:55 AM
Glowsock
Sep 11, 2015 11:09 PM
