where is the rattling coming from?
Old Mar 15, 2003 | 06:12 PM
bad_ta_05's Avatar
Car: 85 trans am
Engine: 79 4 bolt 350
i have a set of flowtech headers and y pipe and when you open the hood you can hear it rattle pretty bad on teh passenger side and at first i thought it might be a loose valve lifter but now when you accelerate you can hear it shake farther back and it rattle pretty bad and the hole time you accelerate from a stop. does it have anything to do with my exhaust beeing too close to the bottum of the car? when i put on my headers and y pipe i had to jack up the middle of the exhaust and rig it up so that it wont rub the ground. can anybody help me?
Old Mar 15, 2003 | 06:20 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Check the Y pipe clearance around that corner near the front wheel.
Also check the tube that goes to your catalytic converter, it might be rattling against the y pipe.
xxx3man`
Sep 23, 2015 10:37 PM
mantaguy
Sep 1, 2015 08:39 PM
aaron7
Aug 26, 2015 09:45 AM
mustangman65_79
Aug 8, 2015 12:07 PM
