Just put Hedman Hedders in!!
Old Mar 16, 2003 | 08:19 PM
Vegeta198's Avatar
the actual headers werent too bad, but getting the y-pipe on and lining up the collector gaskets was a PITA...it took two people...one notice - anyone planning to do this with Hotchkis SFC's, ur gonna have to cut the y-pipe to clear them...anyway big difference driving it now
Old Mar 16, 2003 | 09:21 PM
MdFormula350's Avatar
congrats on the install!!
Old Mar 16, 2003 | 10:18 PM
quicklil87lt's Avatar
i just spent 5 and a half periods at school installing my headman headers. it ran real nice for a lil while. like the first hour or so.now my car seems to run rough. would the o2 sensor not being plugged in plus the lack of my cc carb cause that? before installing the headers i got bad gas mileage cuz of the carb but it still ran smooth. now it seems to run kind of ruough. it seems like there is more vibration and acceleration is a little bit slower. could the headers have liejk melted plug wires and cuased this or soemthnig else? i'm waiting to get the right plug wires for my mallory distributor. so when that goes in i won't have to worry bout the bad timing advance from my distributor due to the ecm.
Old Mar 16, 2003 | 10:35 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
gotta have the O2 plugged in.
also check your plugs
Old Mar 16, 2003 | 10:38 PM
well my hedman headers have no fitting for an o2 sensor to plug in. theres nothnig anywhere on the whoel header or the y-pipe for an 02 sensor or anythnig
Old Mar 16, 2003 | 10:45 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Then you'll need to get an O2 bung for it and weld it in. It's either that or get rid of the CC carb.
Old Mar 17, 2003 | 04:23 PM
oooo i forgot to mention i already got rid of the cc carb and put an edelbrock 600 cfm carb on it. i'm getting horrible gas mileage at the moment cuz of the cc distriubtor and no cc carb and now the o2 sensor is gone. but the distributor should fix it all because it doesn't even hook up to the ecm
Old Mar 17, 2003 | 05:20 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you didn't have a CC carb then the O2 sensor wasn't doing anything anyway.
Old Mar 17, 2003 | 11:22 PM
kfoley's Avatar
Car: '85 Z28
Yep, get rid of that CC distributor and get a HEI one. If you are mechanically inclined I suggest you get a core distributor from a junkyard and get the Proform rebuild kit from Summit for $80. They don't have it listed in their magazine, but I can get you the part number if you want.
Old Mar 18, 2003 | 04:55 PM
i already have a mallory dual point mechanical advance distributor, jegs coil, and i just got back from winners circle with my msd wires i needed to put in the distributor. i'm installing all of it tommaroow at school. putting in the new distributor and stuff should improve my gas mileage right?
Old Mar 18, 2003 | 07:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If it's mechanical advance only, it will still be lacking. You need a vacuum/mechanical distributor for a street car.
Old Mar 19, 2003 | 07:45 AM
bigals87z28's Avatar
Car: Check The Sig
quick, which headmans did you get? the ones w/o air tubes? what are the p/n for the headder and y pipe..68749 and 17470?... thoes are the ones im looking at getting...
Old Mar 19, 2003 | 09:37 PM
i got the 68470. they are the short headers without the air tubes. they made a noticeable difference but i also put in my new coil, distributor and wires at the same time. i like them alot. the only think i have to do to get them to fit was to move one brake line back about 1/4 of an inch. took about 5 hours with a cherry picker and a buddy helpin me. o i also had a lift to use to get underneath. that helped alot
Old Mar 19, 2003 | 09:56 PM
Car: Check The Sig
well i hope i dont have that 5hr problem!!! i have ramps to put the car on so i can get the headers either from on top or from the bottom.. oh well im glad to hear about the gaines you felt. thanks man
Old Mar 20, 2003 | 07:03 AM
well it would have taken like 3-4 hours but we had to kinda ,ake my exaust work cuz i already had it kinda just thrown together.
Old Mar 20, 2003 | 10:45 AM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
i bought the same ones... i dont see a fitting for my o2 sensor either but i'll probably have to drill and weld... i hope mine go in easy
Old Mar 20, 2003 | 05:56 PM
Vegeta198's Avatar
yep those are the ones i have on..i would definately recommend getting the copper gaskets like i did....i just had my local exhaust shop weld in a fitting around the collector, no prob..
Old Mar 20, 2003 | 05:58 PM
Car: Check The Sig
this is a pic from jegs of teh y pipe.. isnt that the 02 bung?
Old Mar 20, 2003 | 06:22 PM
TransAmTBI's Avatar
Engine: 305 TBI
that defanately look like a bung but i def did not get that with mine.. maybe the ones without air doesnt have a fitting for o2.
i'll def get the copper gaskets though now considering the one i got were folded!! lol
Old Mar 20, 2003 | 07:18 PM
Vidman's Avatar
Car: '86 Iroc
Transmission: T-5 with Pro-5.0
Yes, that sure looks like an O2 bung to me, but, the ones I got in yesterday do NOT have the bung, even though the guy at JEG'S told me there was one on it. He ALSO told me the y-pipe was 3".... NOT!!!. I am having a local guy weld on a fitting for my sensor. One question.... I don't have access to a welder so I guess it'll be ok to install headers/y-pipe and drive it to a local shop for welding the y-pipe together?
Old Mar 20, 2003 | 09:46 PM
Car: Check The Sig
you could just clamp it together and then go... welding that is gunna be a pain...
hectre13
Sep 8, 2015 03:38 PM
Chiknhawk
Aug 23, 2015 05:54 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
