Removing Smog & A.I.R ( Emmisions? )
I am putting in a 350 T.P.I engine in my camaro. I have all ready remvoed th enite heating system from the car & I am thinking about removing the smog pump & A.I.R as well... How much worse will the car be on emmisions, becuase I knwo here in Ontario the emmisions testing is pretty brutal. But I do know, that if you change the engine in the car to different then stock, u can run the car under modified vehicle & u have higherlimits to play with?
Has anyone done this, do u notice a gain in HP?
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
you wont notice a gain in HP. it basically just cleans up the engine bay.
not sure about how you will do with emissions testing though.
-Brian
-Brian
well i gained something..
removed the smog pump, and a.i.r stuff, 180 stat, a/c delete at the same time.
with those mods i beat my friend three times in a row, which he use to beat me by alittle less than a half a car...
it seems to have more top end now or at least better response... and it definitely helps to clean up the engine bay...
Car: 1991 Camaro RS
-B
Car: 1991 Camaro RS
it could have possibly been the weight savings from removing the a/c, depending on how much of it was taken out. or the t-stat could have added a couple ponies...who knows. so many things with thirdgens are hit or miss, could be anything, but i am still doubtful that it had to do with the smog pump delete.
-Brian
-Brian
