how can i put duals on
Old Nov 10, 2001 | 12:46 AM
camarofrmhel2002's Avatar
hi i got an 83 camaro with a worked 305 i have long heedmen headers and i need to put duals on my car how can i go about this??
Old Nov 10, 2001 | 03:15 AM
Tas's Avatar
Tas
Why do you need duals?
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
Old Nov 10, 2001 | 04:10 AM
Timmys88Z's Avatar
Find an exhast shop and have them make the pipes and throw a couple of mufflers right in front of the axle, and dump them right there, no tail pipes.
just run the pipes straight on back.
Old Nov 10, 2001 | 12:24 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
See my post in the other thread "Getting dual exhaust need help"...
Old Nov 11, 2001 | 02:13 AM
88IROCZJG's Avatar
Car: 1988 IROC-Z
Engine: stock L03
Transmission: auto
Maybe it is just my car, 88 IROC-Z like in the name, but I was told true duals were impossible by 4 different exhaust shops. I wanted that true dual sound but it just wouldnt work. Maybe it is just the little bit new camaro's and yours would work. I had to go all the way to the back axle and split it there.
Old Nov 11, 2001 | 05:26 AM
Timmys88Z's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 88IROCZJG:
Maybe it is just my car, 88 IROC-Z like in the name, but I was told true duals were impossible by 4 different exhaust shops. I wanted that true dual sound but it just wouldnt work. Maybe it is just the little bit new camaro's and yours would work. I had to go all the way to the back axle and split it there. </font>
It is NOT impossible. MANY have done it. I dont know what it is with these thirdgen people they have to say it cant be done. I plan on doing it soon, when i do pictures will follow.
Old Nov 11, 2001 | 10:57 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
<font face="Verdana, Arial" size="2">Originally posted by Timmys88Z:
....... and dump them right there, no tail pipes.
</font>
Won't that be loud as hell? I had a '71 Chevelle set up like that and even when I was 20 yrs old I could only take it for about a week. Then I had tail pipes put on.
To each his own, I guess.
AJ
Old Nov 11, 2001 | 02:06 PM
Tas's Avatar
Tas
Its doable. Most people don't do it well though. Better off with a real catback system.
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
Old Nov 11, 2001 | 09:10 PM
shutch's Avatar
duals on thirdgens are very doable. i try to tell everyone- just have your exhaust shop run side-by-side pipesand route them through the stock location. the only place where any true difficulty occurs is when the pipes go over the rear axle. the fit is tight, but manageable. next come the mufflers, and the pipes can exit at opposite sides, just as they do stock. believe me, it won't sound stock, though. done right with the right mufflers, it'll sound better than any cat-back i've ever heard, or owned.
i would discourage getting glasspacks- mine was too loud 'til i had the packs removed
Old Nov 13, 2001 | 10:04 AM
VampireHunterC's Avatar
Well, I just put headman headers on my '84. It also has a 305. It took about 10 hours with my father-in-law and I both working on the car. We had to remove the starter, move the alternator, remove the a/c compressor (did not have to disconnect it, fortunatly, we just laid it on top of the engine) and had to jack the engine up about a foot to get enough clearance on the sides to slip the headers in. We also had to cut the bracket that holds the ac compressor so that it would fit over the header tube.
customblackbird
Aug 15, 2021 10:16 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
onefreakz
May 14, 2018 12:15 PM
86White_T/A305
Aug 17, 2015 12:16 AM
