What do excessively rich or lean mixtures do to a catalytic converter?
Old Mar 28, 2003 | 09:19 AM
blue86iroc's Avatar
Car: 1986 IROC-Z
I'm going to be adjusting the air/fuel ratio in my car's computer soon. For normal driving, I'm going to maintain a 14.7:1 air/fuel ratio with the car's computer. At WOT, the mixture might go as rich as 12.5:1, and at cruise it might be as lean as 15.5:1. I have an annual emissions test, so a catalytic converter is necessary for me. Are those ratios too extreme for a cat? What will happen if they are?
Old Mar 28, 2003 | 11:38 PM
Charyou Tree's Avatar
IIRC...
If you run too rich, your exhaust can heat up, and/or you'll have unburnt fuel burning in the exhaust. High temperatures in the Cat will melt the catalyst. Higher temperatures also produce NOX...
Old Mar 29, 2003 | 07:14 AM
blue86iroc's Avatar
Car: 1986 IROC-Z
Originally posted by Charyou Tree
IIRC...
Does a melted catalyst cause a restriction in exhaust flow?
Old Mar 29, 2003 | 12:21 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
definetely and can also cause chunks of it to get inside your muffler and cause blockage there too.
Old Mar 29, 2003 | 08:48 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
I see... so would those air/fuel ratios I mentioned be too much for a cat?
Old Mar 29, 2003 | 11:39 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
the leaner the mixture the hotter the exhaust.....the richer the cooler it is..
that being said, running too rich, will plug your cat with deposits...and running too lean could burn it right out as well as other things
Old Mar 30, 2003 | 08:38 AM
blue86iroc's Avatar
Car: 1986 IROC-Z
Right. What I'm asking is are those *specific* ratios overkill for a catalytic converter? Is there a way to tell (without destroying a few cats)?
Old Mar 30, 2003 | 01:05 PM
Car: '91 Camaro RS
youd have to be waaaay off in either direction to really hurt the cat in a short amount of time.....
youd be so far off though that your engine would run like sh*t....if it was that lean youd be in danger of burning a piston, it would ping and run hot as hell......
if it was rich enough to plug the cat it would make horrible black smoke, foul plugs, have awful throttle response etc.
as far as ratios, its tough to say, but very very far from 14:1
Old Mar 30, 2003 | 05:32 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
Thanks 383, that's what I wanted to hear .
Old Mar 30, 2003 | 05:33 PM
Car: '91 Camaro RS
no problem
Rally Smith
Sep 14, 2015 06:59 PM
Camaro_383
Sep 11, 2015 11:28 PM
m00n420
Sep 11, 2015 02:39 PM
89fast5oh
Sep 8, 2015 09:55 AM
Jk_Under
Sep 8, 2015 08:13 AM
