Hooker worth the extra $$$ over SLP??
Old Dec 8, 2001 | 01:25 AM
BAK12484's Avatar
Just have a quick simple question... are the Hooker Super Comp headers worth the extra money than the SLP's?? I am not worried about having a Y-pipe fabricated if i get the Hooker as i am going with a true dual setup (no emission testing in Michigan)
Btw, what are some manufacturers of good X-pipes and would i really benefit from having one installed or just having two seperate tubes??
Im planning on having the hooker super comps, the x-pipe possibly, no cat, and two race mufflers (moroso maybe) dumping at the axle... tell me what you guys think...thanks!
Old Dec 8, 2001 | 01:03 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Hooker more expensive than SLP, I thought the SLP headers were way more expensive. Jegs has the supercomp for $370.
2 Tickets to game= $250
Gas= $20
Sitting 20ft. from MJ= Priceless
'86 IROC T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK HEADERS Hooker CatBack
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Dec 8, 2001 | 02:34 PM
BAK12484's Avatar
...my bad... the SLP's are only 1 5/8 right??
I was lookin at the prices for Hooker 1 3/4 coated which is $570 (which is what i want)... sorry, my error.
Old Dec 8, 2001 | 06:17 PM
Gta-Paladin's Avatar
In total the hookers will cost you a LOT more than the SLPs. The hookers super comp long tubes will scrape on just about everything... They're better for TRACK ONLY.
Then you fab your own y pipe or get a mufflex y and 4". I ordered the slp 1 3/4" headers. I'm going to get top gun coatings in Calgary alberta to coat them for 100 some canadian. 75 american. they've got some issues but they can be fixed.
Also X pipes are for TRUE Dual exhaust cars
Old Dec 8, 2001 | 09:03 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
<font face="Verdana, Arial" size="2">Originally posted by Gta-Paladin:
</font>
When I talked to the Top Gun folks back in August, they wanted $250 to coat my Hooker Shorties and two weeks to do it!
What is going on with this new $100 business?
BAK12484's Avatar
yeah i figured the hooker would cost a bit more...but as far as flow rates/performance are the hooker worth the extra bucks??
And i wont have to worry about fabbing a y-pipe as i will be doing a true dual setup, thus the need for an x-pipe...any recommendations for one??
and exactly how much lower are the hooker super comp's than slp's??
One last question... how do the hooker long tube and shorties compare to each other??
Old Dec 9, 2001 | 12:10 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
SLP's come in 1 5/8" and 1 3/4" sizes, and are awesome headers. I have no experience with Hooker long tubes, but I've heard great things about them for race cars.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
318 RWHP, 419 RWTQ
13.23 @ 107.62 MPH (2.13 60')
Southern California
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Dec 9, 2001 | 07:00 PM
cort351w's Avatar
Hey buddy, I am doing almost the same setup. I'm using SLP shorties and car-sound cats, so I only have room for an H--that way I don't have to cut the floor pans.
For a good X, go with dr. gas (www.drgas.com). I've had them recommended to me by people who know their stuff. Plus, look on the site for who uses dr. gas.
Only problem is that you need to know where to put the crossover. I have heard that an H should go as close to the collectors as possible (although this is illegal if you are emmisions tested). I have also heard to put the H twice the length of the headers (port flange to collecter along the pipes) away from the ports--so the length of the header away from the collector.
I have also heard (most commonly) that for any crossover, put in your system with no crossover first. Then either spray lacquer or draw heavy crayon lines along the pipes, back from the collectors. Run the engine for a for a while and see how far back the lacquer or crayon line burns off. Where it stops, put the crossover. This is fine for an H, but you would waste a lot of pipe with an X. Sorry, buddy, don't know what else to tell you.
Personally, I think $100 is pretty steep. If I had had room to use an x, I would have first (I was going to do this, but decided not to modify the floor) tried to fab one from two mandrel u-bends. Just cut out the area where they would intersect and weld them together. 2 bends (hooker bends from summit) cost about $36.
Old Dec 9, 2001 | 07:06 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
In a recent post someone said that shorties really just increase flow which is a big improvement because the stock manifolds are so bad but that, in addition to increasing flow, long tubes are also tuned which is a whole lot better etcetera.
I was going faster than I'd ever gone before but then I fell off.
Old Dec 18, 2001 | 03:04 PM
Phil87IROC's Avatar
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
Here's my Hooker SC/LT setup. I never scrape on the road unless I am totally reckless on hilly back roads or parking lot speed bumps. These Hookers sound and perform awesome!! My car sounds like a NASCAR late model or a Grand American modified!! Check it out.........
http://www.geocities.com/cfrios/Phil87IROC.html
Old Dec 19, 2001 | 02:03 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
Since when is SLP cheaper than ANYTHING???
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
