loudest exhaust
loudest exhaust
i already have a borla exhaust on my 86 rs, but i want it to be louder. my friend suggested a cut-out, but i was just going to buy a new one all together. i just want my car to be as loud as possible and sound good. what exhaust system should i get? or should i just go with the cut out?
I wasn't aware they built an RS in '86, Thought that they were brought back in '88. Anyway, the loudest possible exaust system so to speak, would be this: To start, either a hollow cat, or the cat fully removed and a piece of 3" straight pipe welded in it's place. Then, a mandrel bent intermediate pipe either 2 3/4 or 3", routed back to a 2 chambered flowmaster muffler with only one outlet. Then a single 3" exaustpipe out the back off the flowmaster. A friend of mine has this on his '87 fomula 305, and it is very loud. remember, one pipe is always louder than two since all the sound is concentrated out of one large diameter exaust pipe. Plus they dont make a stock replacement flowmaster in two chamber, only three chamber and it is a quieter design and also has dual exaust outlets. Since I personally prefer duals though, I have the three chamber muffler. Finally, headers and high flow Y-pipe would really set it off for you.
'92 RS Heritage Pkg, 305TBI,automatic... CURRENT MODS..Melling 207:214 roller camshaft, Large snorkle air cleaner w/ K&N filter, Injector spacer, ACCEL super coil, Taylor wires,power pulleys, 6* timing advance, flowmaster catback exaust, hollow cat, '95 Z28 exaust tips, P245/50/ZR16 tires, Edelbrock strut tower brace, Edelbrock panhard rod, frt & rear urethane swaybar end links, urethane sway bar bushings, subframe connectors, urethane track bar bushing, KYB shocks, F41 factory performance handling package,Z28 tranny centrifical governor, and more to come soon!
Transmission: 4L80E/4L80E
I must be getting old. I don't equate "as loud as possible" with "sounds good". Did I miss a memo?
I'd prefer "quiet as possible" coupled with "best performance possible". I would be quite happy if the '57 was as quiet as the Camaro if it ran as good as it does now.
"Loud as possible" just creates enemies. I don't know about you, but just being the owner of those two cars is enough to get me enemies without trying any harder at it. And I hardly ever drive the '57 through the neighborhood at midnight anymore (unless eliminations have gone long).
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
I like loud... I can't explain it... but I like to hear what the engine is doing. I think the loudest set-up is a cut-out after the Y. This also alows you to retain a quite system for "stealth mode".
johnyIROC 1983 Z28
"5.0 is way too slow"
-NEW and improved with 355 CID!
johnyIROC 1983 Z28
yeah i agree with you, i want to be loud. my freind has an 01 z28 with a slp loudmouth exhaust and it is so loud and sounds sooo good. i know im not gonna get mine to sound as good as his but i definately want it to be as loud as possible.
<font face="Verdana, Arial" size="2">Originally posted by johnyIROC:
but I like to hear what the engine is doing.</font>
Car: 2012 Corvette Grand Sport 'vert
Engine: LS3
Transmission: 6L80
Axle/Gears: 2:73
<font face="Verdana, Arial" size="2">Originally posted by GetAtMe:
Z28 with a slp loudmouth exhaust and it is so loud and sounds sooo good</font>
The only possible downside is the 2000rpm drone, which is a bigger problem on the A4 cars than it would be with a T56 car, since you can shift around it...that 6th gear comes in handy!
Death Before Front Wheel Drive!
Gruesome death before sUVs!!
1999 Camaro Z28
Navy Blue Metallic, Neutral Leather, MN6, Hurst Shifter, ASR, PS cooler, 12 Disc CD
Mods: Skip shift eliminator, FRA, Direct-Flo + K&N, SLP LOUDmouth!, Black Billet Grille, 1970 Z28 emblems, Dark tint
1999 Trans Am WS6 Convertible
Bright Red, Graphite Leather interior, Black ragtop, A4, CD, no air baffles...
Former owner of a 1983 Z28, 1990 RS
if u have the original muffler on it, just take it off, and put an acetylene torch down the inflow chamber, it will burn the rest of the packing right out, then u have loud exhaust, and if u get stopped for it, then u can say, hey pig, i have a muffler see...that tip came from my uncle, we restore muscle cars and he knows his **** lol
Car: 99 Formula
Axle/Gears: 342
They didn't make an '86 RS.
2 Tickets to game= $250
Gas= $20
Sitting 20ft. from MJ= Priceless
'86 IROC T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK HEADERS Hooker CatBack
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Gas= $20
GM GOODWRENCH 350
KN AIRFILTER
Heres my plans for my 89 RS, Ederbrock headers to str8 pipes all the way back, no cats, to two mufflers with glass packs and 3 inch all the way, everything 3 inches.
Still decideing who I will by from.
un4givin89
Poor Mans White Face Guages
MikeKey.net - Camaro Enthusiast
un4givin89
why not just headers and end right there?? lol
un4givin89
un4givin89
david068513
Sep 18, 2015 10:36 AM
