Dynomax
Old Dec 5, 2001 | 10:10 AM
88greyiroc's Avatar
Dynomax
I was wondering if anyone on here has the dynomax super turbo muffler or turbo i can't remember what its called my friend has one on his mustang and it sounds really good i was wondering how they would sound on a 350tpi with the cats gutted.So if you have one or know what they are like give me some input on themn please.
Old Dec 5, 2001 | 01:30 PM
87ROCZ's Avatar
Car: 1987 Camaro IROC-Z
Engine: L98 bored .40 (357 ci)
Transmission: Race Ready 700R4
Axle/Gears: 9 bolt 3.70 posi
I am running a Dynomax Sport Turbo with no CATS and it sounds great... it isn't the loudest exhaust going (but I wasn't looking for that when I bought it) but it has a nice throaty growl from 2000 rpm's up.. at idle it has a low rumble...
Not like a Flowmaster but definitely a nice sound for sure. I recommend it.
1987 Camaro Iroc Z
T-Tops
Maui Medium Blue
5.7 L TPI
TH-700R-4 Tranny
Dynomax Super Turbo
Removed Cat
Check out my ride in the Readers Rides
https://www.thirdgen.org/rides/index...ew&rideid=6920
Better to look at it than to look for it "
Old Dec 5, 2001 | 01:33 PM
87ROCZ's Avatar
I should have said "Super Turbo" not Sport (had a Sport turbo on my Sunbird GT). And I expect the sound to improve as the muffler gets "broke in". When I finally get a set of headers I think I will have the perfect sound that I am looking for.
1987 Camaro Iroc Z
T-Tops
Maui Medium Blue
5.7 L TPI
TH-700R-4 Tranny
Dynomax Super Turbo
Removed Cat
Old Dec 6, 2001 | 08:02 AM
88greyiroc's Avatar
The reason why i asked was because my frinds mustang has dynomax turbo mufflers on it and his car has a really nice low tone too it like a low roar or growl and i was wondering if it would sound the same on our cars?i am mixed up cause i don't know whether or not to get the 80 series flow master or the dynomaxy turbo , dynomax is suppose to have better flow.
Old Dec 6, 2001 | 05:37 PM
toosloz's Avatar
i have the dyno max cat back....it sounded ok on my 305, but i can't tell on the 355, the geardrive and cam lope are a tad loud
84z28HO
355
open element/k&n
m5/hurst billet plus shifter
83 z28 fiberglass hood
10bolt w/3:42posi
gm aluminum driveshaft
performer intake
performer 600cfm carb
accel 8mm wires
adjustable thermostat switch
160 stat
gta rims
gts blackouts
s.s rear control arms
s.s panhard rod
s.s subframe connectors
98 camaro rear springs,shocks
98 z28 leather seats
95 camaro rear view mirror
"wonderbar"
4th gen z28 tips
14.3@95mph
http://www.geocities.com/toosloz/84camaroz28.html
Old Dec 6, 2001 | 08:28 PM
arthur's Avatar
Just thought I'd offer my thoughts on the gutted cat. My cat started to come apart inside and catylist turned sideways, blocking off the exhaust. The engine had nooo power. Luckily it was only the front section that was damaged, and all the little bits didn't go down the pipe into the muffle and rattle around. Back on track, I was running a gutted cat. Now I see it as something I shouldn't have done. If you need the look of a catto pass inspections, then run a straight pipe through the shell or something. What is happening right now in your gutted cat, is that the exhaust gets a chance to expand into this much larger chamber. It is really happy to be getting bigger, and when it comes time to get back into that much smaller hole, it gets ugly. Obviously we know who's gonna win, but it's gonna cost some HP and flow. It is kind of like using progressive headers, that are 1 5/8 at the primaries and progressively swells up to 1 3/4 or 1 7/8. What this does is allows the use of larger diameter headers that don't destroy the bottom end. As the exhaust swells, it 'pulls' itself, creating a vacume behind itself to help the next pulse. Similar to the tri-Y headers.
Old Dec 6, 2001 | 10:08 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
I have a super turbo muffler on my 91 305 TBI and I like the sound. Low rumble at idle. Sounds much better than my friend's 84 vette with no cat and flowmasters.
Old Dec 6, 2001 | 11:22 PM
bzznczzn's Avatar
I have a 3inch cat back with a dynomax muffler and it sounds great. It isn't the loudest muffler, but is has a very nice low rumble at idle and comes alive when you get on it. Also has a great tone when you let off the gas. Also, the dynomax muffler outflows the flowmaster by a large ammount. My exhaust was on the car when I bought it and if not I probably wouldn't have gone with the dynomax muffler, but I am sure glad it is on there. Dynomax doesn't get raved about like many other exhaust manufacturers, but it flows very well and has a great sound. Go's to show you that just because a product isn't used by everyone on earth, doesn't mean it's not a quality product.
Old Dec 7, 2001 | 08:04 AM
88greyiroc's Avatar
I was also wondering if there is a big sound difference if lets say a dynomax turbo muffler was on a 5.0 mustang and one on a 350tpi. or would they be close to the same tone and sound, considering too the mustang has headers but the cats arn't gutted compared to the camaro having manifolds its cat gutted with a straight pipe through it?
1988 Iroc-z (Gun MetaL)
350TPI (38K MILES)
700r4 stage 2 shiftkit
3" cat back exhaust
K&N
Mod Chip
8.8 Race Wire
accel everything
2.77 limited slip
T-Bar roof
Old Dec 7, 2001 | 10:22 AM
dmair5_0's Avatar
Car: 91 Firebird
No. WHile I love my Firebird, one thing is true, it will never sound like a Mustang. Mustangs sound awsome, and it wont matter if you run glasspacks you wont get the same sound form a Firebird. Its the difference between single and dual exhaust. You can make a Firebird/Camaro sound good, but not like a Mustang.
Old Dec 7, 2001 | 02:30 PM
zfever's Avatar
From what i understand, the difference isn't all about the true duals aspect, but rather the firing order of 302 that gives it the different sound. the 305 wont sound like a mustang unless you drop a ford 302 in. I could be wrong, but just saying dont spend a fortune on true duals expecting to sound like a mustang.
Old Dec 7, 2001 | 04:57 PM
88greyiroc's Avatar
Does the dynomax turbo sound somewhat like the mustang does i mean i do have a 350tpi with no cat?
Old Dec 8, 2001 | 11:26 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Do you want your car to sound like a Mustang, or as good as a Mustang?
If you want it to sound like a Mustang, then go buy a Mustang.
If you want it to sound as good as a Mustang, then buy Flowmaster, because that's all anyone with a Mustang uses. And PAXTON. That's all you ever see is a pre-1994 Mustang with Flows and a PAXTON!!!!!!
If you want a great sounding Camaro, then buy MAC, or Ravin', or Borla, or Hooker. etc.
Mustangs do sound good, don't construe what I've said. But a Chevy V-8 has a distinct sound to. They sound just as good as a F-uckers O-nly R-oll D-ownhill, just different.
AJ
Old Dec 9, 2001 | 05:52 PM
88greyiroc's Avatar
don't worry i am getting a mustang convertible but i just like the low tone that the super turbo gave off i already bought the system 2 hours ago off ebay its 2.75 midpipe with 2.5 outs. I didn't want the engine sound of a mustang just the low deep tone so people can feel my car when i drive by.if you don't know what i mean go to dynomax.com and go to sounds then go to the 5.7l firebird super turbo sound and it will tell all.
350TPI (38K MILES)
3" cat back exhaust
K&N
Mod Chip
8.8 Race Wire
accel everything
2.77 limited slip
T-Bar roof
Old Dec 9, 2001 | 06:31 PM
AJ_92RS's Avatar
Oh, I have the Dynomax cat-back. I luv mine. Wouldn't have anything else. Mine's the 2.5" in/ two - 2.5" out. I just cut off the 30* elbows on the tailpipes, and put straight pipes coming out the back using single chrome, angle cut tips on. It changed the sound quite a bit. It has a much more distinct sound now.
Where did you hear 2.75" mid-pipe? That's kind of an odd-ball size, isn't it? Why didn't they just use 3"? That would be a PITA to match anything else up to it, such as a cut out, or if you removed the cat, or even changed mufflers without changing the pipe.
AJ
92 RS w/t-tops 305 TBI Auto.
175K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford Punch 100. 1 - MTX 12" sub
Old Dec 14, 2001 | 07:10 PM
88greyiroc's Avatar
i don't know if its really that yet. i bought it off ebay the guys said it had a 2.75 mid pipe with 2 (2.5 tips)so i will know for sure when i get it.is 2.75 a good size ?would it give me more horse than my 3 inch with the stock muffler does and my cat not gutted because i am gonna gut it first thing.
350TPI (38K MILES)
3" cat back exhaust
K&N
Mod Chip
8.8 Race Wire
accel everything
2.77 limited slip
T-Bar roof
billybob6110
Sep 24, 2016 09:50 AM
Tarizza
Sep 24, 2015 12:57 PM
midias
Aug 22, 2015 01:42 AM
tinybfl
Aftermarket Product Review
23
Mar 15, 2001 10:36 PM
Mikes86SC
Mar 7, 2001 03:44 PM
