True Duel....is it possible
Old Apr 17, 2003 | 07:12 PM
Catchen22's Avatar
Car: 91 Camaro T-Tops
Engine: 3.1L
I got rear ended last night and since I have to replace the exhaust I was wondering If I could put TRUE duel exhaust in it? With two cat converters, two mufflers or one. So can you do this or not?
Old Apr 17, 2003 | 08:02 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
do a search you'll have all of your answers right there. Good luck.
Old Apr 25, 2003 | 08:46 PM
hawaiianguy's Avatar
True duals are possible. I have hooker shorties going into flowmaster 2 chamber mufflers and then the pipes exit in front the rear tires on both sides. No cats, no A.I.R., no smog pump, no trouble codes. Clearance is a problem if you go too fast over a speed bump or you have a driveway that is a little too steep and then suddenly flattens out. Freeway driving is actually pretty quiet from inside the car although my son was behind me and said he could hear the exhaust even with the windows on his 68 Camaro up and his a/c on. He said it really got loud when I accelerated to pass a slower car. I like the sound though. Sounds like American V8 Muscle coming at you. By the way, the car is a 1991 Z28, L98 engine.
Old Apr 25, 2003 | 11:49 PM
TJs57TPi's Avatar
is there anyone who has a picture or diagram of this setup or can show were u can get one?
Old Apr 26, 2003 | 12:01 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Click on my license plate, SC Z below. Then click on the Exhaust link.
True duals consisting of a pair of cats, a crossover, a pair of polished 1969 Z28 chambered mufflers positioned in the stock location and out through chromed '94 Z28 tips. Here's a teaser pic:
Old Apr 28, 2003 | 08:45 AM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
yep its can be done.........under products look at this site:
Flatout Performance
Old Apr 28, 2003 | 10:41 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
that last link looks interesting i am definitely bookmarking that one.
Old May 4, 2003 | 12:45 AM
Catchen22's Avatar
Engine: 3.1L
Hey Willie....do you have any pics where the CATs are?
Old May 4, 2003 | 08:05 AM
Willie's Avatar
Stock location for both cats. And my ground clearance is the same as stock.
Willie
Old May 5, 2003 | 03:30 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Damn Willie,
that is a hot setup you have there.
Very professional install on everything.
okfoz
Oct 13, 2015 02:19 PM
mattcanty
Oct 12, 2015 11:08 AM
91 SrS
Oct 7, 2015 04:32 PM
paul_huryk
Oct 1, 2015 04:27 PM
Djmathis123
Sep 8, 2015 08:42 PM
