Question about coated header temp
searched with no luck. provided the engine is running fine, around what temp do the tubes get on ceramic coated headers? i know uncoated ones have to be hotter than manifolds. but i'd like to know if coated ones will run cooler (and by how much), or at the same temp as manifolds.
I think the coated will run cooler than stock manifolds, but I am not 100% sure on that. When I got my jet hot video they said after only a few minutes you can grab them with your bare hands. Can't do that with stock manifolds.
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
when i first got my engine running i did a heat test. i used a temp gun. you point it at something, pull the trigger and then it tells the temp. i belive mine were around 400 degrees F.
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
While the engine is running, the coated headers will reach around the same tempature as the uncoated headers, but they will dissapate the heat much faster. They will, with adiquite air flow, run a few degreese cooler than uncoated headers. Where you relly notice the difference is after running the engine, the coated headers will loose the heat much faster than manifolds or uncoated headers. With my edelbrocks, after around ten to fifteen minutes, I can touch the headers just fine.
Car: 84 camaro Z28
Engine: 434sbc
i really don't remember. for some odd reason i thought it was 400. if my dad can bring home that temp gun from his work this weekend, i'll test it again. they get very hot, i know that
Car: 84 camaro Z28
Engine: 434sbc
well my dad brought home the gun and today i tested it out. i let the car warm up to around 200 degrees( when the fans kicked on). the hottest they got was a little over 400 degrees. i didn't actually dive it. it just sat in my garage until the fans went on. hope this helps
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Jet Hot coating keeps the heat inside. I would be cooler on the outside & somewhat hotter than uncoated on the inside.
ambainb
Apr 25, 2016 09:21 PM
hectre13
Sep 8, 2015 03:38 PM
