Can you help indentifying these headers?
Car: Z28
Help!!!!
I need a new y-pipe as mine is all but rusted out. I ordered one from a shop here in the UK but the flanges were completely different.....i told them i was running headers.and they said no probs it'll mate up.but guess what..it doesn't.
The pipe they've supplied me is for a standard car whereas mine has an unknown make of header ( they were on the car when i got it! ) They have a 3 bolt triangular flange which bolts onto what at the moment is 2 into 1 y-pipe ( both join at the same place unlike this "factory replacement" which joins up at different points of the pipe )
Heres some pics which might help
Any ideas what brand they are and which aftermarket y-pipes will mate up????
Thanks for your help!!!!!!!!
Cheers
Phil
Cheers
Phil
Car: 2004 GTO
Hmmm...I have no idea what those are.
I do have two brand new sets of SLP headers w/install kit, all Jet-Hot coated. One is 1 5/8" w/dual cats and the other is 1 3/4" with single cat.
Shipping to the UK will be expensive, but these are ready to go with y-pipe and all!
Car: Z28
Yeah that'd be great, i'd love to run a set of those............but Mr Customs always takes his cut as well...just had a load of stuff delivered from Summit and got stung for an extra $100!!!!!!!!!!!!
It'd just work work out too expensive..many thanks anyway :hail:
Anyone else got a clue as what these headers are???
Cheers
Phil
It'd just work work out too expensive..many thanks anyway :hail:Anyone else got a clue as what these headers are???
Cheers
Phil
Car: Z28
Cheers RICHRAD
So they're hedmans......i'd better order a hedman y-pipe then!!
Does anyone have a pic of the hedman y-pipe just so i can make double sure?
Phil
Phil
It's your y-pipe that convinced me.. On the hedman headers the flanges are free(not welded) from the collector. When assembled, they are compressed (with whatever gasket used together) for a seal....so they could be the Hedmans once you take them apart to find floating flanges....
Car: Z28
RICHRAD,
Thanks again......i've had another look around for some pics of the hedman y-pipe and found a few and you are absolutely bang on!!!!!
Definately hedmans!!!
Cheers..you've really helped me out on this one!
Phil
Phil
Car: Z28
Firstly, thanks for your help with this guys!!
I dropped the y-pipe off yesterday for a closer look......guess what? The flanges were free to move about once i slackened them off......so definately hedmans........ I know i said i'd checked against a picture but i just like to be 100% b4 ordering a new part!!!!!
Cheers!!!!!!!!!
:rockon:
Phil
Cheers!!!!!!!!!
:rockon:
Phil
redformula88
Oct 14, 2015 06:08 PM
