In need of some pics!
Old Aug 9, 2003 | 09:22 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I need some of you guys to post some pics of your drivers side headers...I havnt purchased mine yet but I am trying to put my accessories back together. I removed my stock exhaust and when I go to put the power steering backets on it seems they tie back into the drivers side exhaust...do they do that with headers too? If so then I need to wait until I get the headers in before I put the accessories back on.
I hope you guys no what im needing.
Old Aug 9, 2003 | 09:27 PM
here is a pic of where Im at...the red dots represent the bolts holes for the power steering pump. I know the AC bracket ties into the drivers side exhaust.........but does the PS?
Old Aug 9, 2003 | 10:05 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
While I'm certain this isn't 100% accurate and, the other p/s pump bracket was omitted after the 1st removal, here's the best I remember the layout...
Old Aug 9, 2003 | 10:21 PM
my PS bracket must have been the one you omitted...cause mine doesnt look like that. Everything else is the same....
so it does fasten to the header/manifold, huh?
I think that bracket you have is the AC bracket.
Old Aug 9, 2003 | 10:47 PM
justinhebert's Avatar
Part of the PS bracket mounts to the first bolt on the exhaust manifold. The headers will have a thinner flange so all you need to do is make a spacer. You can use some roundstock or just slap a whole wack of washers in there.
Old Aug 9, 2003 | 10:56 PM
DAMN! thats what I thought......that means it would be a waste to even start trying to fit my peices back together and then have to fight to get the headers in around them..... guess I gotta spend more money on some headers now if I want to get my car back together......Headmen elites here I come.....they better be some damn good headers too!....LOL
Old Aug 9, 2003 | 11:29 PM
deadbird's Avatar
Engine: TPI 305/ v6
The 85-87 (82-84, opposite side but, same crap setup) accy cluster-f is the whole reason I spent $200 on a serpentine conversion from TACreations.
The bracket omitted is the one on the backside of the PS pump that goes from lower block to the manifod IIRC (semi-¼ circle bracket). Here's how the center part of of it goes though...
Old Aug 10, 2003 | 01:38 AM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
Pics I have of my driver's side header:
This is all I have. Hope this helps any.
Old Aug 10, 2003 | 08:10 AM
Yep, someone should go smack GM for oming p with such a F***ed up kind of bracket system. Makes so you have to remove it all just to get to, lets just say the water pump......
You got a pic of you current setup? or a link to the conversion kit you have...
Old Aug 10, 2003 | 11:42 AM
deadbird's Avatar
Engine: TPI 305/ v6
You got a pic of you current setup? or a link to the conversion kit you have... [/B]
Here's the link... http://www.tacreationsusa.com/bracke...ccessories.htm
It's a used stock '88-up serpentine setup. I put it on my 'bird and on my friends '72 truck. Def. worth the price on both vehicles IMO. I can't get a complete serp. setup from the u-pull locally that cheap (plus it's just a rarity to see one as well).
Old Aug 10, 2003 | 03:55 PM
yanfoo's Avatar
Car: Malibu 80, T/A 87, S-15 87
Engine: 267 Bu, 305 T/A, 350 S-15
Transmission: Auto Bu, 5spd T/A, Auto S-15
here my pic
here my pic, 87 carbed with vbelt setup.
not the greatest pic, but to cloudy today.
Old Aug 12, 2003 | 09:14 PM
RICHRAD's Avatar
hope these help...
Old Aug 12, 2003 | 09:18 PM
RICHRAD's Avatar
top pic is the A/C bushing of course....this one is the p/s mounting
Old Aug 12, 2003 | 09:20 PM
Originally posted by RICHRAD
hope these help...
Yeah thats what I was looking for...I can see the upper bracket, the lower bracket and the AC bracket.....So it would be wise for me to wait until I get my headers before I go trying to put the brackets back on.......what kind of headers you got? can I see pic of your whole setup?
thanks
Old Aug 12, 2003 | 09:30 PM
RICHRAD's Avatar
I've got the hedman shorties..sent them off to jet-hot....nice coating ... Here's how far along I've got....
Old Aug 12, 2003 | 09:35 PM
RICHRAD's Avatar
Headers will have to go on before brackets...those a/c brackets are the main pivoting adjustments for the p/s pump....you will have to cut out a section of this one in the pic
Old Aug 12, 2003 | 09:36 PM
WOW! VERY NICE! I LIKE!
Old Aug 12, 2003 | 09:41 PM
RICHRAD's Avatar
Also in the pic you posted, about the hole you have circled at the bottom near the timingcover-oil pan ...wrong one I think...you wanna use the hole above that... be sure to put some sealant one the threads there (through-hole I think).. good luck when you get'em
Old Aug 12, 2003 | 09:46 PM
RICHRAD's Avatar
Just alot of clean, paint , and chrome....and a few hours a week...in it's second year i believe...thanks
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
TexasFormula
Sep 30, 2015 06:36 PM
aaron7
Sep 30, 2015 09:15 AM
92projectcamaro
Sep 29, 2015 07:07 PM
