some pix of my exhaust from maniac motor
Old Sep 3, 2003 | 07:53 PM
matts90firebird's Avatar
what do you guys think this is not all of them im gettin it installed as we speak
happy racing
another
Old Sep 3, 2003 | 07:55 PM
last one for now till install
this is the last one for now till install
Old Sep 3, 2003 | 11:06 PM
AUTOGON350's Avatar
Car: 93 S10 blazer
Wow
looks great...... and loud
were you putting mufflers back there?
Im currently pulling my hair out trying to find a way to fit a similar setup on my car. Too bad I need cats and mufflers on mine. however those pic migh have just talked me out of the mufflex 3.5inch $8billion $$$ catback.
anyway that looks good.
was that all mandrel bent tubbing?
Old Sep 3, 2003 | 11:07 PM
bigals87z28's Avatar
Car: Check The Sig
very nice... but where is the cross member? and no cats? where in jersey are you getting tested.... for that matter, where the hell are all you jersey guys getting inspected!!! WTF!!!
Looks very good. How is the clearance near the collectors of the LT's? looks very well put together? are you running mufflers or bullets or what?
Old Sep 4, 2003 | 12:05 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: some pix of my exhaust from maniac motor
Instead of re-posting the pictures, you could have just linked to the original post about them here from a few months back.
I still stand by what I think of the system but, I hope it turns out good for you and you like it though.
Old Sep 4, 2003 | 07:02 PM
well to answer ur questions the cross member is there but it is back further and there is an arm that goes out to the trans mount ill get u all pics when its finished
yes im puttin muflers on there i got 2 40s (flowmasters) they are goin next to the and below the gas tank (my plans might varry to the installer) (i cant weld)
as for the inspection stuff ill have to bring you there i dont disclose that info in the net ..... his *** as well as mine will get ****ed so i dont wanna loose my hook up (cough cough cough) :lala: :lala:
o yea im also puttin 2 1/2 inch flowtech cuts outs on there eventually i will get those electric cut out valves or whatever there called
that exhaust is not my exact setup ill have pix of my car in a couple days i will finaly drive my car again saterday ( if all goes to plan)
all i need now is the timing does any one know timing by the way
i cant seem to figure it out
does it realy have to be right on the money the timing chain part if perfect but where do i put the little arrow on the graph and how do i put the distributer in when i have the crank perfect
thanks guys
Old Sep 5, 2003 | 12:52 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
if your at TDC, then your distro will sit facing the #1 cylinder. yes, it is very important that you have it all lined up correctly if you want this thing to perform well.
Old Sep 5, 2003 | 06:51 AM
but what im trying to figure out is where do i put the line on the harmonic ballancerl...... there are 3 different letters on the tdc mesuring thing
o yea by the way im just makin sure that the cylinder 1 is the one closest to my driver side head light
and im pritty sure that my distributor will only go in one way. it seams that there are 8 different settings, but will only set into one correctly all the way down so i can put the retainer to hold it down
thanks guys
btw im picking up my car today ill have pix tomorrow or monday
Old Sep 5, 2003 | 08:45 AM
Car: Check The Sig
there is a little gap in the ballancer. That is where you need to look for. Then you will see the notches in the timing marks.
Old Sep 6, 2003 | 12:20 PM
the cars is done
ill get pix to you guys asap
o and dont buy that ****in piece of **** exhaust from maniac motor i had to pay 300 for the install because it does not fit
we had to modify it
****ing ****ers (sorry moderators)
now all i have to do is time it
and i tried the whole tdc thing with a screw driver in teh spark plug hole then faced the distributer to the #1 cil and i could not get anything
so **** it ill just have a gas station charge me and arm and a leg to do it
o well
Old Sep 7, 2003 | 12:40 AM
Car: Check The Sig
Hey matt, if you want and if you can wait 2 more weeks, come to my house and ill check and change your timing for a 6pack of bee... soda!!
Old Sep 7, 2003 | 07:52 AM
if i could get her to start i would definatly take up up on that offer for soda because im only 19 cough cough 21
if you want i should be up and running in a couple days ill have good year time it for me
the guys on rt 22 love working on drag racers and **** like that
take it easy
Old Sep 9, 2003 | 11:59 PM
talk about a raping for this exhaust
dont buy the maniac motor exhaust
i does not even fit
those ****ers make it seem to be all great but it ****in sux
they were acting like they built it on a 3rd gen and ran it to make sure of leaking holes
but the pipes that go over the axle dont reach the ****ing x pipe
my welder was cool enuf to fix that ****ed up mess for me
but at a total days cost of $300.00
if you want my advice go to minakee on rt 22 in springfield and he will fab one for you if your nice
1992 Trans Am
May 10, 2023 07:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
xxx3man`
Sep 23, 2015 10:37 PM
TheExaminer
Aug 26, 2015 04:59 PM
PestilenceIV
Aug 20, 2015 02:33 AM
