What mufflers should I get for a high 11 second car, LT headers 3inch duals??
Old Sep 7, 2003 | 11:51 PM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
The exhaust shop doing my exhaust this week is trying to talk me into using their "shop" mufflers, which in this shop/s case is a pair of Magnaflow 3inch offset inlet, center outlet mufflers, the "shorter" of the two designs magnaflow has. I'm running hooker super comp headers, and a 3inch X pipe true dual exhaust (to be installed this friday). Do you think I should go with the magnaflow's or something smaller/lighter/better flowing for more ground clearance? Really don't want to rob power, so I WOULD go with dynamax bullets, but I think with the LT's, 3inch piping and the solid cammed 11:1 motor in the car it will be REALLY F'n loud.
Old Sep 8, 2003 | 06:03 PM
KYL98's Avatar
Car: 1991 Z28
The Moroso Spiral Flow mufflers are good. They are shaped about the same as a bullet muffler...but a little different in sound. I heard a T/A with an LT1 and dual exhaust with an Hpipe and it sounded mean. Its similar to your setup...with a couple exceptions. The Borla XR1 shootout mufflers are REALLY good...but they arent cheap. They sound great on big block dirt track cars.......Good luck...sounds like it'll be mean
Old Sep 8, 2003 | 07:02 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
none
Old Sep 8, 2003 | 10:05 PM
BillZ28's Avatar
Car: 84 Z28
Dynomax Race Bullets
Old Sep 8, 2003 | 11:23 PM
Irocster's Avatar
Car: 1989 IROC-Z
Transmission: 700R-4
One of Spintech's racing mufflers.
Old Sep 9, 2003 | 04:57 AM
EvilCartman's Avatar
Car: '82 Z28
Spintechs buddy of mine has a '66 chevelle running dual 3 1/2 and is running 9's in the 1/4 mile.
Old Sep 9, 2003 | 07:34 AM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
My Father has Magnaflows on his 86 Z28. He runs a 355, 12.5:1, mechanical roller 264dur @ .050 .624lift 110lca with dart II's. He is also running LT headers with 3" duals that dump just under the rear axle.
I take it out a lot since he drives it maybe 2 times a year(hes almost crippaled ) Anyways, those are very loud mufflers! I went through a car dealership and set off at least 5 car alarms on the way in, and again on the way out......while @ idle putting through...Do you like it loud?
Personally i would sacrafice 5-7hp to be able to still mess around while burning around town. I had Edlebrock Race Series mufflers on my S-10 for a bit, and people would come say to me " I saw you floor it back there, nice!" and in reality I was only up to 3000rpm. So I put on a set of Flowmaster Big Block II mufflers (Flowsmasters quietest ones)and found cops left me alone more than before and I was driving harder and faster = more fun!!:hail:
Old Sep 9, 2003 | 11:09 PM
rleprechaun's Avatar
Car: 1987 TransAm
Engine: 350 Goodwrench
Check out Mufflex's new exhaust system to go behind your Hooker Super Comp headers.
Old Sep 9, 2003 | 11:48 PM
Car: Junk
where are they for sale at?
Old Sep 10, 2003 | 07:30 AM
Car: 1987 TransAm
Buy direct at
Mufflex-performance
2369 Nottingham Way
Trenton NJ 08619
www.mufflex-performance.com
609-890-0481
When you check out the web site go to intake& exhaust then what's new for pictures. You will want a TPI-Y with your carb. car.
Old Sep 10, 2003 | 09:47 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i second the moroso spiral mufflers. they aren't quite as loud as the bullets but still have good tone quality. my dad is running them on his as i will be on mine in about a month when the car is back together.
Old Sep 11, 2003 | 02:28 AM
Car: Junk
I've pretty much decided on using magnaflow's or spiral mufflers........but just out of curiousity.......how much is the whole y pipe/system for the mufflex?
Old Sep 11, 2003 | 03:43 AM
Car: 1987 TransAm
With choice of Spintech or Flowmaster $748.75.
Old Sep 11, 2003 | 02:16 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Hooker Aerochambers. My car has that "chambered" sound like flowmasters only they dont have that high-pitched tiny sound. Its more like a deep roar. Best way to describe it is "flowmaster with *****"
Old Sep 13, 2003 | 07:14 PM
Car: Junk
YIKES!! Guess I'll be going with my custom made X pipe 3inch duals for $300 then Decided on Magnaflow Race 3inch offset inlet, center outlets. Getting installed monday, I'll let ya know how it sounds. Already know how aerochambers 3inch straight in/out sounds, thats whats on my Girlfriends car.
1992 Trans Am
May 10, 2023 07:19 PM
onefreakz
May 14, 2018 12:15 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Linson
Aug 21, 2015 02:12 PM
Exxon Limited
Aug 9, 2015 08:13 PM
