I highly reccomend Locking header bolts
Old Sep 9, 2003 | 10:44 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I've had problems with the header bolts coming off on the 90, so I bought a set of locking header bolts from a speedshop and it made me happy. I no longer have exhaust gaskets leaking. Just be sure you do not loose any of the c-clips, they do not include extras.
Old Sep 17, 2003 | 01:34 PM
txhotRS's Avatar
good good advice.. and I would also suggest using soft copper gaskets, with those locking header bolts... you WILL NEVER have to replace gaskets again, or have blowouts... it's a little extra money.. .but for not ever having to swap header gaskets... IT'S DEFINITELY WORTH IT
Old Sep 17, 2003 | 09:44 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i got the Percy alumin dead soft header gaskets with the stage 8 lockin header bolts and so far after about 3 months no leaks
Old Sep 18, 2003 | 01:39 AM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Same setup as Tim above ^, no problems whatsoever. Never had to touch the bolts except when I pulled the motor out last week. Well worth the money IMO.
Old Sep 18, 2003 | 06:35 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I bought a set of Stage-8 locking header bolts a while back ...I can't even put the clips on cause the bolts are too close to the header tube. Only way would be for me to sit there and grind down every single clip. I'd rather just re-tighten them every now-and-than
Old Sep 18, 2003 | 09:00 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
with those little clips i ended up grindin about 4 of them down to make them fit and it only took a few seconds.
Old Sep 18, 2003 | 09:04 PM
MdFormula350's Avatar
yeah i never used the ones i bought either, just slapped on the slp bolts in the kit i bought. i put the headers on over 3 months ago and the bolts look tight (havent touched them since then), i try moving the headers around from time to time they dont budge so i assume they are tight enough.
Old Sep 23, 2003 | 07:34 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
If your non-locking header bolts don't come loose, you don't have enough cam!!!!!!!!!!:rockon:
Old Sep 24, 2003 | 10:24 PM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
haha, true
edit: sigged
Old Sep 25, 2003 | 12:01 AM
kfoley's Avatar
Car: '85 Z28
ROFLMAO!!! Those sigs are great!
Old Sep 25, 2003 | 01:38 AM
MarkB's Avatar
Car: 1982 T/A -1986 Z28
Engine: 383 -305
Transmission: T56-700r
or your machinist forgot to balance your reciprocating assembly
Old Sep 25, 2003 | 11:11 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
whoa.....
You really need to check them with a tightening tool, like a wrench.
If you can actually move the header, you are in trouble....even a bolt that is loose a half turn can make it leak.
I've heard you are supposed to tighten them after 100 miles, then 500, then 2000, and then you should be good until you ever loosen them.....
I check mine all the time just in case cause header leaks are probably the most annoying thing I can think of while drivin'....
Old Sep 26, 2003 | 09:59 AM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
But how hard are they to remove when you want to take them off? Are the clips even reusable?
Old Sep 26, 2003 | 10:10 AM
kfoley's Avatar
Car: '85 Z28
Not hard at all, it's a simple as removing an e-clip (a small scredirver is all that's necessary) and then pulling the actual bolts out, if they're stage 8, then its real easy to get to all of them with an allen wrench. When I took mine out it didn't take me but 15 minutes and all the bolts were out. As far as the clips being reusable, yes they are, but if necessary you can find new clips at most hardware stores fairly cheaply.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Out-Cast
Aug 22, 2015 07:49 PM
Dialed_In
Aug 20, 2015 01:45 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
