my true dual idea
Old Sep 15, 2003 | 04:37 PM
underdave's Avatar
Car: '91 Firebird vert
Engine: 305 TBI
Transmission: auto
my true dual idea
i'm probably gonna end up doing this soon. hedman full lengths bolted directed to purple horny glass packs. emissions tests don't exist in kansas city, so that's not a probably. what kind of problems will i encounter with the install on the headers? and how does the setup sound? i figure it shouldn't be too hard, there's no pipes or cats. just glasspacks bolted directly to the headers. comments?
headers:
http://store.summitracing.com/partde...rt=HED%2D68460
glasspacks (i still laugh every time i hear "purple horny" ):
http://store.summitracing.com/partde...rt=BIG%2D50231
Old Sep 15, 2003 | 04:52 PM
darbleinad's Avatar
Car: 84 Trans Am
that is likely not gonna fit. once you get the hedmans in and see where the collectors end up, you will see what i mean. you will need to put some pipe on to the collectors. the pipes will have to bend down some, away for the floor and the tranny pan.
Old Sep 15, 2003 | 04:54 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
why not do a little better job and do this
headers:
http://store.summitracing.com/partd...art=HED%2D68460
Extensions
http://store.summitracing.com/partde...rt=HED%2D18804
Buller Muffs
http://store.summitracing.com/partde...rt=WLK%2D24215
Tube
http://store.summitracing.com/partde...t=SUM%2D640025
bring it back to where ever and dump it. or take it all the way back
darbleinad's Avatar
Car: 84 Trans Am
by the way, the reason i know this is that i just installed some hedman long tubes. i hooked these into my existing true dual exhaust setup.
Old Sep 16, 2003 | 05:57 PM
underdave's Avatar
Engine: 305 TBI
Transmission: auto
i'm glad i asked before i got everything.
so, if i get some s-bends, everything will fit. but which muffler would be better between the purple hornies and dynomax magnum glasspacks? anybody have better experiences with one or the other?
Old Sep 16, 2003 | 07:48 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
I'd definetly use some kind of muffler rather than glasspacks.
Old Sep 16, 2003 | 11:11 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
They're OK if your name's Billy Joe Jim Bob, your mom's also your sister AND you're aunt, and your hat says "Old Style".
Old Sep 16, 2003 | 11:40 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Then they still aren't good for performance
Old Sep 17, 2003 | 10:37 PM
AJ_92RS's Avatar
You have NO sense of humor.
I was talking about the SOUND of them.
AAMOF, change the name to Waldo, and take out the "sister, mom, aunt" comment, and I just described my grandfather. Or is that ALSO too much humor for you to handle.
Anyone who doesn't know that glasspacks don't perform anymore than a coffee can muffler IS as dumb as a *******.
They also sound horrible (unless they're on a '55 Chevy or similar type of car). If you're gonna run glasspacks (not you brody) then you may as well grow a ****** to.
No flame intended. I guess my sense of humor's as old as I am, and you younguns just don't understand it.
Old Sep 17, 2003 | 10:41 PM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
also they will be unbearably(sp?) loud...so very loud
Old Sep 20, 2003 | 08:43 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
i used a set of the cheap "raptor" mufflers from flowtech for my true-dual setup.
they have aquired about 3 exhaust leaks since they are so LOW they hit about every little pebble in the road, but they sounded good before the leakiness.
doesnt quite sound like a chevy though, almost sounds like a mopar, or a really big ford motor, really strange
and im serious too.
Old Sep 20, 2003 | 09:09 PM
rattlesnake_dm's Avatar
Car: 1992 RS (25 th Anniversary)
Engine: 350 Miniram XFI
Transmission: Pro-Built 4L60
I've got Hedman full length headers and I did the exact setup that is being talked about here, 'cept I used Cherry bombs for mufflers, it's alright, 'cept that cause I had to go under the tranny cross member the pipe hangs way too low, only have like 3 inches of clearance from the road, it scrapes alot over speed bumps and train tracks. It'll get me by for this year, bit I'm trying to find a better system. Just my two cents...
Old Sep 21, 2003 | 09:41 PM
underdave's Avatar
Engine: 305 TBI
Transmission: auto
all i ended up doing was removing everything from the cat back and putting a single glasspack where the cat used to be. it's loud and sounds good, and it'll be good enough for now. i'll save up and get a good catback system, because i can't afford to lose any ground clearance to duals. oh well, it was a good try i guess.
Old Sep 21, 2003 | 09:57 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
.... i can't afford to lose any ground clearance to duals....
You don't have to:
http://members.optushome.com.au/iroc...st/exhaust.htm
Old Sep 21, 2003 | 10:01 PM
underdave's Avatar
Engine: 305 TBI
Transmission: auto
yeah i love your system, definitely the best i've seen. i should've also said that money is also a factor. someday though, after i win the lottery, everything will be fine.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
beastin91rs
Oct 9, 2015 07:38 AM
formula_novice
Sep 5, 2015 03:58 AM
Dialed_In
Aug 20, 2015 01:45 PM
