Exhaust idea
Old Sep 22, 2003 | 09:48 AM
stupid4901's Avatar
Exhaust idea
I was looking to do something new with my exhaust and thought about getting hedmann longtubes and connect them to a short length of pipe and then a chambered muffler that would exit some where behind the front wheel and to the side. Would this work?
Old Sep 22, 2003 | 10:38 AM
mastertrixter's Avatar
Car: 82 z-28
Engine: L69
Transmission: muncie T-10
you could do it, but your looking at clearance issues and a very loud exhaust.
Old Sep 22, 2003 | 11:12 AM
stupid4901's Avatar
What if I used shortie headers? All i want to do is have a dual exhaust, and the idea of going all the way to the back is a little too costly right now. Any other suggestions?
Old Sep 22, 2003 | 05:14 PM
Car: 82 z-28
Engine: L69
shortie headers are a pain to install, and if your doing it your self and all the welding, then u could do shorties, use flowtech warlock mufflers, because they have the thinest case, and run the pipe and have them exit just in front of the back tires. that would make them much quieter and it would still be a problem as far as ground clearance.
Old Sep 22, 2003 | 10:14 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
chambered mufflers are so loud you have no idea! love the sound of all the little back fires when you put it to the floor.
Old Oct 4, 2003 | 05:50 PM
stupid4901's Avatar
So, is there a way to run dual pipes without going all the way to the back, and not having it deafeningly loud? Even if it dumps like midway of my car hatwoud be easier then going all the way to the back.
Old Oct 4, 2003 | 06:16 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
shorties are no harder(useally easier) then any other header.
warlocks are not the thinnest.. spintechs are.
why a dual exhaust if you're not doing it for power?
in anycase, anything dumping under the car will be alot louder then it pointing away... it will vibrate the floor and you will feel it in the whole car.
for duals, i would run long tubes, and tuck up like most Y pipes do, then instead of them Y-ing together, id just have them run parallel.. *shrug*
you major prob is the shape of the floorpan... if you try to go under it at the wrong points, its just too low.
Old Oct 4, 2003 | 06:48 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
I do!
Hmmmm... never heard this before on mine.
Old Oct 4, 2003 | 07:00 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
willie, do you get a nice snap-crackle-pop when yuo downshift though?
Old Oct 4, 2003 | 07:21 PM
Willie's Avatar
No, not really.
Old Oct 4, 2003 | 08:10 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i have hooker long tubes and theres no way to make the exuast exit right after the front wheels. if u look at my car u can see the end of the collectors and how it would be hard to put a muffler under there and have it exit after the front wheels.
Old Oct 4, 2003 | 08:52 PM
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
tim
do you have any picture of how the exhuast is ran over the rear???
Old Oct 4, 2003 | 08:58 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
no but it goes back into the hooker cat back i have on there. i have the Hooker long tubes with the mufflex ypipe back into the hooker cat back
Old Oct 5, 2003 | 08:32 PM
Car: 82 z-28
Engine: L69
tim
about running them out just behind the front wheels, it can be done, just not with long tubes, u'd have to go shorties, and be a masterful pipe bender and a damn good welder to make it work.
Old Oct 6, 2003 | 08:24 PM
1989RS's Avatar
Car: 1989 rs camaro, 1990 jeep wrangler, 1995 eagle talon tsi awd
Engine: nothing right now
Transmission: j.w. performance th350 3500 10" stall... soon to be t56
yes you can run longtubes and run an exhaust to the rear axle and not have it deafeningly loud and....still have it cheap, if you know how to weld. my whole exhaust cost me $160 and its 3"
hedman 2 1/2" x-tensions
summit h-pipe kit
8 ft sec. of 3" pipe
dynomax bullet race mufflers (x2) 3"x12"
your favorite brand turndowns and hangars
and it looks something like this:
Old Oct 7, 2003 | 03:33 AM
Car: 82 z-28
Engine: L69
hey, 1989rs
how much ground clearance do u have with that setup, a side shot would be great if u could post one
thanks
AussiePr0nCar
Mar 6, 2020 04:04 PM
Vintageracer
Jan 10, 2020 05:33 PM
MintWS6FORMULA
Oct 19, 2015 08:53 PM
gta power
Aug 13, 2015 06:15 AM
mustangman65_79
Aug 7, 2015 09:55 PM
