What causes that lopey sound?
Old Nov 25, 2003 | 10:10 PM
Abubaca's Avatar
I know it's the cam, but what's actually happening in an engine that makes the specific sound?
Just curious.
Thanks.
Old Nov 25, 2003 | 10:50 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
usually it's valve overlap....when both the intake and exhaust valves are open at the same time....it has to do with longer duration camshafts...
typically you give up idle quality and low rpm quality for the engine to make power more efficiently somewhere else in the RPM band...ie....usually higher up.
Old Nov 26, 2003 | 01:56 AM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
i would take that sound over any 4cyl with a blow off valve any day.
Old Nov 26, 2003 | 06:01 AM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
Old Nov 26, 2003 | 09:09 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you could make a honda lope.
just rig the VTEC silinoid so that its running off the big cam at low RPM...
Old Nov 28, 2003 | 08:21 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
this guy i used to work with at pepboys has a 1990 or 91 eagel (sp) talon tsi awd and he's pushin about 500+ hp and the cams he has in it , it lopes like a ****, im sorry to say but it actually sounds good for a 4 banger but he's also pushin like 25-30 lbs of boost on pump gas and about 42-44 lbs on race gas.
Old Nov 29, 2003 | 01:09 AM
Stokdd's Avatar
Car: Yellow '92 Formula
Transmission: A4
Whoa now....44lbs of boost? I think not.
Old Nov 29, 2003 | 02:28 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
actually yeah he runs 44 lbs of boost. there isnt anything stock in the motor, the turbo is bigger then youyr head
Old Nov 29, 2003 | 04:28 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I'm sure that possible... remember, he said race gas.
And yea, its overlap that causes that sound, but solid lifters add a nice sound to that lope too
Old Nov 29, 2003 | 09:27 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
the 1500hp blown alcohol big block in our race truck has about 25lbs at maximum boost, granted its waaaaay more volume...just to put things in perspective though
Old Nov 30, 2003 | 07:50 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
44psi of boost can mean anything.. The guys who run the honda race shop near my shop run 30-50psi turbos on their little vtecs, but in actual airflow its prolly about the same as my 8psi supercharger.. Its a measure of restriction, which is why its such a lame way of judging - and there is absolutly no way to calculate boost vs hp. You can only calculate fuel + air ..
-- Joe
Old Nov 30, 2003 | 07:55 PM
reilly8282's Avatar
Car: 1988 IROC
Engine: l98 350 tpi
ever been to a local circle track? they sometimes have 4 cylinder series and they have really lopey sounding exhaust notes, you ought to check it out its actually pretty cool granted its got just 4 cylinders
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
