true dual sound clips/ opinions and ideas
Old Jan 21, 2004 | 08:54 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
anyone got sound clips of true duals with bullet's or chambere's mufflers? I'm working on a true dual setup (much like Deadbird's) and can't decide what I want to run. I thought about running two chambered mufflers in place of the straight pipe before the rear axle ( paralell with the driveshaft) or two bullet mufflers right after the axle before the tips. Ideas, suggestions welcomed!!
Old Jan 21, 2004 | 09:38 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I can tell you that bullets with tips just off them (as I had) will give an outrageous bass tone making the mnotor sound like way more than it really is (my 305 has about 4x more growl than my dad's 396 impala w/dual 2¼" & turbos). The more length you add after the mufflers outlets, the more it will start to have that hollow, smoothe toned sound. Still bassy at certain rpms and cruise downs but, nothing even close to bullets at the rear (the reason I changed my setup). I am aiming for a certain sound similar to a name which rouses peoples temper so I won't say but, the bullets are roughly toned similar to the afomentioned vehicles that have flowmasters with just turndowns, only a little louder at wot.... according to my hearing anyways.
Old Jan 22, 2004 | 06:50 PM
Engine: LB9/383
Thanks man. That's what I need. PM me with the name of the aformentioned person Just wondering.
Old Jan 22, 2004 | 07:26 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
http://dodds.cc/chad/garage/z28/ls1_...true_duals.htm
Mostly LS1's but you get the idea.
Old Jan 24, 2004 | 09:01 AM
Engine: LB9/383
any of you guys have thirdgen soundclips? LS1's sound nothing like SBC's. Thanks though, I did get some ideas from the site.
Old Jan 24, 2004 | 03:00 PM
deadbird's Avatar
Engine: TPI 305/ v6
Try doing a search for willie's setup... he had a short vid/sound clip of his. I had one but, like everything else including my mind, I've lost it. Wasn't very good quality anyways though.
onefreakz
May 14, 2018 12:15 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
beastin91rs
Oct 9, 2015 07:38 AM
Dialed_In
Aug 20, 2015 01:45 PM
