Need Help Fast
Old Feb 15, 2004 | 05:14 PM
red85berlinetta's Avatar
Need Help Fast
can some one please tell me as to how to get my dynomax super turbo exhaust on... we have put it on stands and we still cant the the middle pipe to go over the axel? is there a method or anyone that has done this before please help... any ideas appreaciated.. thanks
Old Feb 15, 2004 | 08:14 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Need Help Fast
How do you have the rear of your car jacked? Make sure that the rear is sagging down so that you have the most room possible.
Old Feb 16, 2004 | 12:29 AM
i have the rear on stands that you drive on to... so i should jacj the front of the car?
Old Feb 16, 2004 | 09:21 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
This is what I would do if I were you. Whenever I work on the rear of the car I either jack the rear under the pumpkin and rias it high enoug where I can get two jack stands under the car in front of the rear wheels. Look for the worn spot where shops jack your car. Put your jack stands there and when you release the jack your rear end will hang free and you will have tons more space. See your rear is in its loaded posistion right now if you let it hang it will be in its unloaded posistion. You should have no problem now.
InfernalVortex
Apr 20, 2021 11:31 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
sreZ28
Oct 22, 2015 08:21 AM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
