Which Headers?
Old May 16, 2004 | 10:15 PM
meeklay812's Avatar
Car: '89 RS
Engine: 383 in progress
Transmission: TH 700-R4
Which Headers?
I already have a flowmaster cat back, but would like headers to go with it. What would be the best cost effective headers for my application? Thanks alot
Old May 16, 2004 | 11:13 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
Cost efficent, Headmans
Pros:
Cheap
They're Headers
Cons:
2.5" Y-pipe.
Best headers(IMO) Hooker 2055's
Pros:
3" Y-pipe
Cons:
pricey.
Old May 17, 2004 | 12:16 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'll disagree on two points:
1) They're "Hedman".
2) They're "hedders".
Old May 17, 2004 | 12:36 AM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
haha.
whatever you want to call them
Old May 17, 2004 | 10:20 AM
five7kid's Avatar
No, that's what they call them and themselves.
Old May 17, 2004 | 10:56 AM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
Yeah i know, but no matter what hedman calls them, they are still headers to me
Old May 17, 2004 | 02:39 PM
meeklay812's Avatar
Car: '89 RS
the hooker 2055's say there for TPI engines, i have the 305 LO3 Carb. Would this still work?
Old May 17, 2004 | 04:32 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
YES!
DO NOT buy any exhaust part that says it is for the L03.
You will only be hurting your performance.
Old May 17, 2004 | 04:48 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
I thought L03 was a throttle body injected engine?
Old May 17, 2004 | 07:26 PM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
I just installed some Hooker 2055s on my Carbed 1984 L69. It will work for sure. Only thing is the AIR setup on the drivers side is set up for TPI. So you have to get a 180* fitting.
Old May 17, 2004 | 08:47 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It is. Are you going to replace the cat as well? If so, get a system that is desined for TPI applications. The exhaust routing is the exact same between the two and will have the larger y-pipe collector size. I would get a 3" cat with any header set that you choose. It is pointless to change one without the other on TBI cars. I to would recomend the Hooker 2055's. I would also take a look at the mac hedders. Besides SLP these are the best hedders out there for your car.
Old May 17, 2004 | 08:54 PM
meeklay812's Avatar
Car: '89 RS
Okay thanks, that helps alot
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
