dual-cat replacement
Old Jun 28, 2004 | 11:47 AM
PAformula's Avatar
Since PA has new inspection laws that require all emission components to be in place, I have put my cats back on my car. I have the dual-cat set-up and need to replace one of them. Has anyone replaced just one before? If so, what size do I need?
I see that my good cat has a curved end and different ID's front and back.
Thanks!
Old Jun 28, 2004 | 12:27 PM
VA1991Z28's Avatar
Car: 1991 Z28
Transmission: 5-spd
I replaced both of mine on the stock Y-pipe with Random Technologies - they will have what you need, but Random Tech's are expensive. Recently one of these cats just went bad and I will be replacing the entire Y-pipe with a Carsound/Magnaflow - I haven't seen anyone else mention this. It's 2 1/2" Mandrel bent stainless steel with 2 9400 series high flow CarSound cats. The entire Y-pipe & both cats costs less than the 2 Random Tech cats. Here is the urlhttp://www.car-sound.com/directfit/df_218.htm
It totaled something like $363.00 shipped. I haven't put it on yet but looks well made. One thing though is, the end of the Y-pipe, which attaches to the cat-back is now a slip-on and is 2 1/2" ID and 2 5/8" OD - I plan on having the pipe expanded to fit inside the 3" Banks cat back I just bought.
Good Luck.
Old Jun 28, 2004 | 12:37 PM
PAformula's Avatar
thanks, I have the flowmaster amer. thunder cat-back on now and I assume that would cause problems. I saw catco universal high-flow converters on ebay for $32 each. I think the inlet size of the OEM converter is 2.25" Does that sound right?
thanks
Old Jun 28, 2004 | 01:43 PM
VA1991Z28's Avatar
Car: 1991 Z28
Transmission: 5-spd
2.25" inlet does sound right, but I have a 305, not a 350.
Old Jun 28, 2004 | 07:19 PM
Kwik89GTA's Avatar
Car: 1989 Bright Red GTA
Engine: Grand Sport LT4
Axle/Gears: 10 bolt 3.73
http://store.summitracing.com/partde...=27814&from=MG
Summit has High flow cats for $280
Old Jul 1, 2004 | 09:44 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
i got cats, but it says that it only has 1 catco converter, if order that from summit will i get all of what it is shown, or will i only get the cats?
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
