Problem after header install
Old Oct 21, 2004 | 08:43 PM
1bdbrd's Avatar
Car: 1991 Trans Am
so i installed a set of hedman shorties and y pipe last week. got it done and took it for a drive and when you take off from idle it has a very very bad stumble. so much so that the car almost dies. this mainly happens at about 2k rpms or less. anything above that and the car pulls like it should all the way to about 5500 where i shift.
what should i look for? all the sensors should be properly connected, all the plug wires are on the correct plugs as far as i know (did the job twice to make sure). it is running an open y pipe and the smog stuff has been taken off. what should i look for?
i also noticed an SES as soon as i start the car but i thought that it would be for the smog stuff not being there.
Old Oct 21, 2004 | 10:35 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Try removing the cap on the distributor check if the rotor and cap are in good condition. Mine did the same thing when I installed my 1 5/8 slp headers on my 92 RS.
Old Oct 22, 2004 | 10:41 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
First place to start would be to see what code it is throwing that SES light.
Old Oct 22, 2004 | 11:58 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Agreed. See what the computer thinks is wrong first. I'd also check your plug wires, make sure they are all connected properly. Did you tighten up the O2 sensor enough? is there a leak around it?
rocn7roc
Sep 21, 2021 02:16 PM
Wesly_66
Aug 26, 2015 09:55 PM
Fronzizzle
Aug 17, 2015 02:52 PM
TheJoeY88
Aug 13, 2015 06:51 PM
drathaar907
Aug 6, 2015 04:20 PM
