Fastest single four inch exhuast third gen?
I'm just wondering what are some of the faster cars with a single four inch.
I am just intersted in what a car with 1 3/4 hooker super comps a mufflex three inch y and single foru inch is capable of?
I have heard of cars in the low nines with this exhuast, is this really possible?
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
Being one of those in the low 12 second club, and soon to be part of the (hopefully) low 10 club, I can say without a shadow of a doubt, that a single 4 inch system will not sustain a car into the nines. Compounding this problem is the use of nitrous. A 4" exhaust (single) will be very restrictive for a 383 running 200 horses of nitrous. Mufflex is an EXCELLENT quality street/strip exhaust though. I own a setup.
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
i know of a guy that runs high 9s low 10s with an 85 IROC that has a turbocharged 305 in it, he has a 3" random tech catback
Transmission: Th350
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
There is a guy here in our local club that runs high 7's/low 8's (soon to be the fatest LS1 on the earth) on his 382 Turbo LS1 through a 4" ypipe and cutout.
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Here's something to think about....
George Baxter ran well into the low 9s, maybe even high 8s with a 4" Mufflex.
If you don't know his car...it's a convertible 4th gen Camaro with a Vortech-blown 383 Gen I small block that puts out well over 900 hp.
I read he switched to a true dual Borla muffler setup and ran a few tenths quicker but trapped the same mph. He believes the heavy weight of the 4" system was costing him some ET, but not horsepower.
Unless someone is putting out serious hp like Mr. Baxter, then a 3" system is more than adequate into the 10s.
Transmission: Th350
I have personal experience...I switched from a 1 3/4 SLP shorty with a mufflex 4" setup to a 1 7/8 setup with true dual 4" exhaust and dropped from 12.3 to 12.1. I have not yet finished the fuel system on my new motor, so I can't tell you what kind of times it will post, but for nitrous, bigger is always better. You can get away with a 1.94 intake valve well into the 9's as long as you have a 1.7 exhaust. Cylinder pump is the enemy of nitrous. Getting that exhaust out is key. I am not a turbo/blower guy so I cannot speak to you about that, but if you are running nitrous, generally more flow = lower et.
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
the best turbo exhaust is no exhaust! they only work off pressure in the manifold. most turbos have at least a 2 to 1 ratio in the exhaust maniflod vs boost. did you say you have a dual 4in on a car that runs 12s?
Transmission: Th350
12's on the old 355 motor. The new motor should run low 10's sprayed if I can hook up. It is an ovalized 4", meaning i put it in a press and ovalized it. It isnt really an exhaust, so much as a muffler off the header and small length with a turndown. Doesn't even exit the car.
Transmission: Th350
I cant find my Mufflex pictures!!
This is a pic from last year but you can see the low point of the mufflex system with a 4" y pipe.
This is a pic from last year but you can see the low point of the mufflex system with a 4" y pipe. Junior Member
Car: 1986 F250 4x4
Engine: 365HP, 510 lb/ft TQ 460
Transmission: C6
the benefeit of true duals is that you can flow a lot of air AND have the velocity stay high
Car: 84z28
Engine: chevy 388
i would have to say yes you can get into the nines with a 4 inch exhaust.
you can see my simple site at:
http://darcom.org
http://darcom.org
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
buddy of mine was running hooker and mufflex and was trapping around 142 in his 82 sport coupe, last i knew though he switched to true duals, havent talked to him for a while
Car: 88' Iroc-Z
Engine: LQ9
dual 2" flows more than a single for im pretty sure it has to do with surface area i read it in a post a while back. bigger is not always better
Car: 1986 F250 4x4
Transmission: C6
Pi x r^2. 2" diameter has 1 inch radius. Truncating pi to 3.14 you get: 3.14x1x1= 3.14. Times 2 for two 2 inch pipes is roughly 6.28.
4 inch single= 2x2=4x3.14= roughly 12.56 sq.in. flow area, as opposed to 6.28 for dual 2 inch.
3 inch duals= 1.5x1.5=2.25x3.14= 14.173
3.5 inch duals= 1.75 x 1.75= 2.8425x3.14= 8.92445x2= 17.8489
It's simple mathematics. And considering all exhaust tubing has .040 inch wall thickness, actually try the equations with these numbers:
1.92 in for 2 in
3.92 in for 4 in
2.92 in for 3 in
3.42 in for 3.5 in
:lala:
1.92 in for 2 in
3.92 in for 4 in
2.92 in for 3 in
3.42 in for 3.5 in
:lala:
bjpotter
Jan 22, 2019 12:27 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
sailtexas186548
Aug 26, 2015 03:32 PM
