crossflow vs single tailpipe
Old Dec 6, 2004 | 07:25 PM
1984HO's Avatar
Car: 1984 Z28
Engine: LQ9 W/ Howards ASA cam+Fast 90
Transmission: T56 Mgw shifter
Axle/Gears: Currie 9inch w 4.30 gears
hey guys i have a 305 in my 84 Z28 it has the usual holley carb, performer intake, bigger cam (not sure of specs, but 15-16" vacuum at 900 rpms) 700r4 w/shift kit 3.73 and will soon have a new limited slip. right now i have a 3inch i-pipe back into a flowmaster 80 series with dual 2.5 inch tips, but im wonder if maybe i would be better of with a single 3" tailpipe system ie: 3inch i-pipe to mac 3" offset/offset to single 3" tip. the reason i' m considering this is that it is quite loud but also i feel it has to much resonance and is just a little louder than i would like. so what do you think of the single 3" tip idea? would this increase my perofrmance or decrease or remain the same
Old Dec 6, 2004 | 10:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Do you have a cat? I'll assume you do not.
The resonance is probably coming from the lack of a cat. For a 305, the performance difference between what you have and what a single outlet muffler would offer would be next to nil. I chose that muffler because I liked the balanced look of dual opposite outlets better than a single or same-side duals, and figured the 305 wouldn't overwhelm the muffler.
To cure the resonance, put a 3" Bullet muffler where the cat is supposed to be.
Old Dec 6, 2004 | 10:35 PM
b00sted's Avatar
Car: 1969 Camaro Z/28
Engine: Stock DZ302
Transmission: M21 Muncie 4-spd
Keep the setup you have...Just add a second muffler like Five7 said. It doesn't have to be some awesome muffler...Just a straight-through style that won't fall apart after a few months.
Old Dec 7, 2004 | 04:38 PM
1984HO's Avatar
Car: 1984 Z28
sorry i have a catco 3in high flow cat, basicly i just want a muffler slightlt quieter than the 80 series i have now and while im at it figured i would get one that would flow better than the flowmaster cause from what i have read on here they are less than ideal what do you think?
Old Dec 7, 2004 | 06:15 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Old Dec 7, 2004 | 06:17 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
the flow 80 aint that loud. LOL
try edelbrock muffler
its quiet and flows a ton
Old Dec 7, 2004 | 11:32 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
If you still wanted the flowmaster sound, but quieter and don't mind the single outlet, you could get a 50 series. It's only 1 or 2" longer.
Old Dec 9, 2004 | 12:55 AM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
I have a Single In / Out Flowmaster 40 DeltaFlow (supposed to lower interior resonance) Its as load if not maybe a little louder than my old Flowmaster 80. The 40s does have some interior resonance but at cruise with the radio on you can’t hear it at all, with the radio off it’s hardly noticeable.
Here is a small video of it the day it was installed its oggten a little louder with age as do all flowmasters.
http://members.***.net/-nuclear-/going.mpg
PS I bumped the Shifter into nuteral on accedent and i also know now my tail light is out.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
86IROC112
Nov 7, 2015 06:50 AM
Night rider327
Oct 9, 2015 09:25 AM
LT1Formula
Oct 8, 2015 08:34 PM
dusterbd
Sep 29, 2015 08:40 AM
