Y pipe bolts broke when taking them off!
Old Jan 15, 2005 | 12:59 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
what do i do now??!? i felt the bolt in the back where the y pipe meets and it feels that the bolt is made into the header part where it bolts to the y pipe.. do I have to know take off each header and drill holes for new bolts? or do these actually bang out???
Old Jan 15, 2005 | 01:11 PM
Car: 2002 SS
Engine: Ls1
Old Jan 15, 2005 | 01:23 PM
Car: 2002 SS
Engine: Ls1
Old Jan 15, 2005 | 01:59 PM
Car: 2002 SS
Engine: Ls1
Old Jan 15, 2005 | 02:08 PM
Car: 2002 SS
Engine: Ls1
WHAT DO I DO
Attached Thumbnails Y pipe bolts broke when taking them off!-picture-008.jpg
Old Jan 15, 2005 | 03:26 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
You can buy a tool that kind of looks like a drill bit that is a bolt remover, if you can get to it. Here is a type call an easy out. I think that is what I have at home, but I'll have to look. I've never used it, so I don't know how easy they are to use.
http://www.toolprice.com/category/screwextractors/
http://www.tools-plus.com/hand-tools-extractors.html
Old Jan 15, 2005 | 04:27 PM
Car: 2002 SS
Engine: Ls1
i dont it? hows it supposed to take the bolt out without messing up the teeth on the manifold? does it like go in couter clockwise and it turns the bolt to the left at the same time?
Old Jan 15, 2005 | 04:34 PM
Car: 2002 SS
Engine: Ls1
and look at this.. how am i supposed to stop this other side from moving? do i have to take the steering pump out? i think thats the power steering pump.. but anyway.. i can manage to get a wrench in there.. if i do have to take the pump out right there... i looked for a way to take the tension off of the belt.. theres like no pulley that slides like the alt or anything wtf
Attached Thumbnails Y pipe bolts broke when taking them off!-picture-010.jpg
Old Jan 15, 2005 | 10:22 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
get a dremel, and cut the bolt from the middle, one the manfilds are out then you can worry about removeing the rest.
thats what the guy with my edelbrock headers had todo.
I sat for 3 days with pb oil and stuff trying to get them darn things ouit, i got one out with the pb oil. the others, i got very creative with my dremel, and pretty much, but a hole around the bolt and had a guy weld new ones in place for me. hehe..
But the sectiopn between the two franges just get a cutting tool and cut that darn biatch....
shane
Old Jan 15, 2005 | 10:27 PM
Car: 2002 SS
Engine: Ls1
yeah i could do that.. i could just drill the bolts out then get new bolts.. slide them in the holes then weld the bolt in
Old Jan 15, 2005 | 10:28 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
and you have to pretty much take the a/c ompressor off, and the power steering pump brackes off also.....
They are all mounted to the manifolds. when we did my headers swap, we cut the parts that connected to the manifolds clear off, i hated them sun of a guns.
Its not that hard, my first tiem i had some help, as long as you dont get into anything majorly mechanical you should be fine and what your doing is the easy stuff, if you cant do this, then why are you taking them off?
Old Jan 15, 2005 | 10:31 PM
Car: 2002 SS
Engine: Ls1
this is cake.. no matter what i do i'll never give up and eventually get it done.. i just dont wuna fck anything up.. i'm doing this cause i have a downpipe with a glasspack and couldnt weld on top of it because of the floor board .. so if the whole exhaust was off itd be easy..well it turned into something bigger lol oh well
Old Jan 16, 2005 | 01:18 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Yea, dude, I know how it goes. I took my headers off to put some new ones on.... two weeks later, I still don't have the exhaust put back on. 'well, since I have this off, I might as well do this', and on and on and on.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Terrell351
Jun 13, 2021 01:13 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
hectre13
Sep 8, 2015 03:38 PM
transaero
Aug 31, 2015 01:14 AM
