How to limit exhaust Reversion - Back Flow
Car: 1983 Z28
Engine: 350 CID
Transmission: TH-350
Hello,
I've got Edelbrock tes headers and true duals without x or h pipe.
The other day I decided to put my hand over the exhaust pipe. I covered it COMPLETELY.... and the car ran fine... but i noticed something....
THE EXHAUST WAS SUCKING MY HAND IN ... Big time....
The flow going Back into the exhaust was soo bad I cut my hand on the exhaust pipe... because it sucked it in!!!
Now.... is there a way to stop this... i'm sure this is what dilutes the intake charge correct???
A x pipe will just allow the same thing to happen........
I just wanted to know if anyone has any information on this subject. I have read something about A.R headers....
Thank you,
ROb..
1983 Z28 , 1972 2 Bolt 350 w/9.1:1 CR, Ported 416'sw/1.94"/1.50" Valves, z28 springs, Lunati - Bracket Master II
Dur @ .050: 230/230
Gross Lift: .480''/.480''
1.5 Stock Rocker arms/Stock Push Rods, Edelbrock Super Victor
Holley 3310VS, 4.5 power valve, Yellow spring, quick change kit
TH-350 w/B&M Shift Kit, TCI 10" 3500 Stall, GM HEI w/locked out timing, Accel Super Coil, 3.08 one wheel peel
Edelbrock TES, true duals, No rear sway bars, Fiberglass hood w/2-1/2 inch scoop
Futura 245/60R15 front/rear
S-10 Manual Steering Box
Best Time
60 ft ---- 2.209
330 ft ---- 6.109
594 ft ---- 8.648
1/8 ET ---- 9.212
1/8 MPH ---- 79.780
Thank you,
ROb..
Dur @ .050: 230/230
Best Time
60 ft ---- 2.209
330 ft ---- 6.109
594 ft ---- 8.648
1/8 ET ---- 9.212
1/8 MPH ---- 79.780
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
If you are only using your hand to cover one of the exits you are creating a pressure differential between the two banks. What you are feeling is the vacuum that is starting form on the bank that you are plugging. It is just like your intake manifold in that respect where you are drawing air out of a controlled plenum.
Car: 1983 Z28
Engine: 350 CID
Actually I have turn downs on the car... if i look close... I can see it sucking up dust from the ground..... of coarse during the next pulse it will spit it out..but.............
I was actuallly thinking of hooking a smog pump directly to the headers..... soo that instead of sucking bad exhaust back into the combustion chamber.... it would be sucking fresh oxegen...
Rob...
Rob...
Car: '90 RS
Engine: 377 LSX
Your exhaust is not sucking in anything back into the combustion chamber. The only residual gasses that enter the combustion cycle are from the EGR function. The slower the engine speed the more distance there is between exhaust pulses. I bet if someone were to rev the car you would have nothing but dust being blown up in the air
Car: 1983 Z28
Engine: 350 CID
wheeeww.. hang on I got something in my eyes....So it's just a low pressure cell behind a high pressure....... just was a little worried that there wasn't any scavaging...
Rob...
Rob...
Reversion would be caused mostly by valvetrain component selection. Exhaust affects it too, but the cam characteristics create it. If you really do believe that you have a serious reversion effect, contact a marine performance shop. It may sound strange to contact them, but if a boat has a reversion problem, its catastrophic. They should know if reversion is a problem with that cam.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
Rob...
Rob...
if you don't mind just out of curiosity would you have a way to hook a pressure gauge up to your exhuast?
