Y-Pipe for 2210's?
Old May 2, 2005 | 01:37 PM
CbrasTsteLkChk's Avatar
Car: '84 Camaro SC/ I-ROC Body Conversio
Engine: Rebuilt 350 5.7L, Edelbrock 750cfm
Transmission: Re-built 700-R4
Axle/Gears: Moser, 3.73
Y-Pipe for 2210's?
Anyone know where I can get a good Y-Pipe to hook up to the Hooker 2210 Headers? The guys at Hooker told me that a company named Mufflex makes it but it's $339 There's got to be something cheaper out there.
Old May 2, 2005 | 02:10 PM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
One way would be to buy a y-pipe and have a muffler shop make tubing to go from that to the headers....would be cheaper.
Old May 2, 2005 | 03:05 PM
shawnc16's Avatar
Car: 86 IROC, 89 GTA
Engine: 350 blocks, both of em
Transmission: 700r4s
Axle/Gears: 10 bolt and 9 bolt, 3.73, 3.23
nope just $275 Its a 3 inch dual to 4 inch outlet.
Old May 2, 2005 | 03:23 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
It'll take some modification. I bought mine used from another member on this board and they had to cut and weld the Mufflex Y-pipe back together at different angles to gain chassis and ground clearance in spots it was rubbing.
Old May 2, 2005 | 04:22 PM
shawnc16 -- do you happen to know if they make a 3" dual inlets to a 3" single outlet?
likeenz24 -- I'm trying to avoid a muffler shop bc around here muffler shops don't tend to deal with anything 3" in dia.
There's a place called AA Speed & Custom (www.aaspeed.com) that will supposedly do any sort of custom exhaust from headers to tail pipes and everything in between. I may just take it to get done there if it's cheaper. I need a flowmaster from a Y-Pipe back anyways and I want to make sure it's done proper due to clearence issues underneath... it gets a little low sometimes
Old May 2, 2005 | 04:28 PM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
On mine I did 2.5 pipe into a 3" flowmaster y-pipe......2.5" pipe should be good for most applications...Ive also heard that the mufflex y-pipe takes alot of modification to make it work, not a direct bolt on....
Old May 2, 2005 | 04:38 PM
Yeah, well I may just take it to this customizing place and have them do it bc they'll do all the work from the Y-Pipe to the Tips, and I know it'll be done right. Thanks for the input.
Old May 2, 2005 | 10:45 PM
shawnc16's Avatar
I know they make the 4 inch out and they have a reducer down to 3 inch for another 25 bucks.
The site is mufflex-performance.com if you wanna check em out.
I just ordered a 4 inch cat back with a spintech muffler and 3 inch dual outs. Damn good quality and all the systems are made for each customer. You wont be dissapointed. It took just over a week.
I happened to get a deal on a y-pipe through the classifieds on here.
Old May 3, 2005 | 09:40 AM
everything hooks right up with no modifications or you will have to modify it like everyone else is saying you have to?
Old May 3, 2005 | 09:53 AM
shawnc16's Avatar
Nothins perfect so you may have to have a few small tweaks. Overall my y-pipe looks like it was just a straight bolt up application.
Old May 3, 2005 | 11:57 AM
Did Mufflex sell you the entire exhaust system together? Or did you get the piping after th Y-pipe througha different company?
Old May 3, 2005 | 12:25 PM
shawnc16's Avatar
I bought a set of Hookers and the y pipe used through someone here. I just ordered the cat-back from mufflex. Its all stainless steel thats why it costs soo damn much
Old May 3, 2005 | 12:32 PM
Ok, thanks for the info.
BTW, how's your ground clearence by the collectors and around the transmission pan and mount? Do you happen to have any pics of the car on the ground underneath?
Old May 3, 2005 | 12:36 PM
shawnc16's Avatar
just to give you a heads up there is a guy selling a mufflex system and y-pipe in the classifieds. I think hes willing to separate
Old May 3, 2005 | 12:37 PM
shawnc16's Avatar
ummm nope. I dont have my motor back yet but i will have some pics very soon next week maybe.
Old May 3, 2005 | 12:41 PM
shawnc16's Avatar
Mufflex y-pipe and catback 4 sale
Theres one
meeklay812
Oct 1, 2015 03:46 PM
Zell1luk
Sep 29, 2015 10:36 AM
Camaro_383
Sep 11, 2015 11:28 PM
hectre13
Sep 8, 2015 03:38 PM
tricky1
Aug 23, 2015 01:17 PM
