How hot does headers become?
Old Jun 19, 2005 | 12:27 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
In what temp range is headers usually at idle? and at cruise/wot?
I'm planning on getting a "laser Thermometer" off ebay and want to make sure It can handle the temepratures from me headers.
Old Jun 19, 2005 | 09:19 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
In the pits they'll be around 525-575*, after a pass or leaning on it a bit I get a ERR on my thermo gun that maxes at 700*
The other truck I run we had Jet-Hot do our headers, now when coming back from a pass it ranges from 250-300* depeneind on which tube you should and where at on the tube you shoot it. Within 2 minutes of shutting the engine off you cna literally grab the header with your bare hands and it's just really warm to the touch.
Old Jun 19, 2005 | 10:46 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Well, mine are burning off paint thats supposed to be good to 1200*.... make of it whatever you want
Old Jun 19, 2005 | 10:51 PM
IHI's Avatar
IHI
Improper application I'd say. I painted old set before I installed them and they held up for 2 years before I sold them, no flakey paint. VHT ceramic paint, torpedo heater used to pre heat headers, then paint was applied in 3 generious coats and sat in front of torpedo heater again......but I know what your getting at
Old Jun 19, 2005 | 11:40 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Then I need one that can show more than 1000 deg F, then.......hmm...
/N.
Old Jun 20, 2005 | 12:13 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
If they are getting to 550-650 you better fix what's causing it before something really goes haywire.
Old Jun 20, 2005 | 12:45 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Really? My 500 degree gun typically tops out with no reading with my ceramic coated SLP Tri-Ys when idling in the driveway in closed loop. What is the usual reason for being too hot? Too much timing or not enough?
Old Jun 20, 2005 | 12:49 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
not enough I would guess..
When we put the engine together we put the dist. in at O deg, then when we put the engine in the car we forgot to advance it, took the car for a drive and the headers were glowing ...........
Just placed a bid on a 1000Deg F. IR thermometer.......
TX-SleeperC5
Feb 24, 2016 01:34 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Chad Speier
Sep 24, 2015 12:32 PM
corey8084
Sep 17, 2015 02:56 PM
hdis2002
Sep 8, 2015 02:52 PM
